| CNC Wood Router Project Log Post your CNC machine building log here only. |
| CNC Darrens Work Log V2 Hi All, Well here goes for the second router build. While I had a lot of fun, learned alot and even made some money with my mostly JGRO plans built router I have always wanted to do my own design. I have run a few jobs on the jgro router but I also had to pass a couple up because of the size of the part that needed to be made, so I made the descision to build bigger. The cut area on this router should be around 4x5', large enough for the jobs that i had to pass on and also large enough for my dad to do some stuff on it for his custom wood working biz. Here are a couple of photos of the linear track idea I came up with. Not really my idea for the design, just the way it was made. The design is straight from Bishop Wiescarver just made my way, as the actual Bishop parts were out of my budget. My design uses roller blade bearings mounted in delrin wheels running on aluminum rectangle cut to match the wheel. |
| Darren, That's pretty nice! What's going to keep the bearings from pushing out of the delrin over time? Trent |
| here are a few shots of the gantry. I can hear a few of you right now...a wooden gantry that big?? Well my family has always been woodworkers i'm about that only one that does a little bit of work metal work on a Smithy 3 in 1 that we have so I went with wood. It is all made out of baltic Birch ply and is very rigid. The slot along the front of the gantry will house the lead screw and will have some sort of belows to cover it and keep the dust out. Also you can see the Igus E-chain that will cary the power, encoder wires and the vacum hose. |
| each roller has 2 bearings, one on each side and an internal flange wich seperates the bearings. Once bolted on the bearing are held into the delrin. Darren |
| Here are a few Rhino 3d renderings. Note I am in no way a CAD person so the drawing isnt the greatest. Doing it in rhino more for fit and placement of things and make sure everything works together. The Z axis is not done as of yet, still alittle head scratching to do on that one. The angle will be welded to a cross bar on each end and all attached to the stand. Darren |
| Did you find a cheap source for the E-Track? I'm about to the point of final wiring on my first router and I'd love to use proper E-Track, but the $150 worth I'd need is a bit much. I don't even need big stuff either, just two pieces to handle a 24" stroke and one for a 12" stroke, all with no more than a 1" square internal size. Pete C. |
| EBAY!! I picked up that piece of e-chain, 6' long 4-5/8 x 2-1/2 for $20+shiping its on there all the time. Do a search for Igus, cable carrier, cable track or cable protector. Darren |
| And the last photo for now, here are the 3 servo motors I will be using on this router. Brand new Pittman lo-cog servo motors with a max peak torque of 410oz/in. These motors were used on equipment that had the encoders not mounted on the motor, so i have mounted an aluminum plate to the back to mount the encoder to. Planning on using a Rutex servo drive to control everything. Darren |
| I think you take the size record for a wooden router. You're off to a great start. I can't wait to see how your project progresses.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
#10
I am tempeted to buy 100 and sell them on the zone for $10 US Great progress on your machine, and some nice neat ideas too, Darren. I had also thought about the twin bearing on each side of a turned V groove wheel too. I will be keenly watching your progress. Last edited by ynneb; 03-22-2005 at 12:03 AM. |
#11
| Well guys more work done. I changed slightly from the plans using square tube to hold the vee rails instead of the angle as I think this should wook better and be more rigid. I got one set of the rails mounted and had to give it a try so I made up a test dolly and bolted on a ser of the vee bearings. It is smother than I could have hoped for! I could give the dolly a shove and it would go to the other end without much force. now to start on the second set of rails and the stand. Darren |
#12
| Here are a couple of new Rhino rendeings of the drawings. Even tho it has taken me alot of time drawing this in 3D, it has been so much easier getting parts to fit together and placed so they dont interfere with eace other! Darren |
| CNC lathe tool and work offsets | mm4039 | General Metalwork Discussion | 18 | 06-15-2005 12:45 PM |
| Are ballscrews necessary for PRECISE work on a cnc lathe? | daytrader | General Metal Working Machines | 15 | 01-10-2005 01:34 PM |
| Some recent work - NON CNC | Hack | WoodWorking | 3 | 01-07-2005 02:58 PM |
| CNC For topo foam work | texasjeff | DIY-CNC Router Table Machines | 7 | 05-08-2004 10:14 AM |
| CNC work on Larger JET milling machine | camfambmw5 | TurboCAD/CAM | 3 | 12-11-2003 09:28 PM |
