Member Steve Palm (spalm) has done this. Check out his posts.
hello I like to get get some feed back from users that have made Dovetail Joinery on there cnc...
I Like to understand there techneques and how easy its to impement on a cnc?. I understand you need to have the abillity to cut long vertical
pcs...of lumber... etc ... making the gantry over hang edge, or make a hole in you table etc...Im more interested in the alignment and settup issues...and design the dovetail...
post pictures if possiable with comment...
There's been a few done on the "Joe's CNC 4x4 Hybrid" here is one example.
"http://www.youtube.com/watch?v=ccS2W2O9CJY"]YouTube- Cutting Dovetails on a Joes Hybrid 4x4 1/2
"http://www.youtube.com/watch?v=7n_s2UoXM7Y"]YouTube- Cutting Dovetails on a Joes Hybrid 4x4 2/2
Joe - those look familiar!
Eliod - I wrote the wizards that are shown in the videos
Here is another video of the stand alone interface that I wrote:
I have since that video made it into a wizard for members of the Joe's CNC site. The first videos that Joe posted, the tool paths were completed in Vcarve. The new wizards operate in mach3 and calculate any number of evenly spaced DT's.
To complete these in vcarve or Aspire - see the following:
http://www.vectric.com/forum/viewtopic.php?f=3&t=5811
and half way down you can see my manually generated toolpaths in Vcarve
http://www.vectric.com/forum/viewtop...=5144&start=15
I have talked about releasing the wizard to the CNCZone Community but have not had a chance to really dig in and make it the gcode clean enough for public use.
Joe's setup is nice, above. I have not seen or used the mach3 magics, but instead created a separate dove tail program that outputs gcode directly. No fancy graphics, and you have to recompile after adjusting your settings, but that is not a problem at all for me. I would be happy to share the ugly code for your information if you may find it useful.
The program makes it really easy to create fully through dove tails, half blind dove tails, evenly spaced or custom spaced fingers etc.
(about the recompiling part, I could of course easily put all the inputs in an editable text file instead if needed.)
/penot
Hi, this wizard seems to be very interesting, is it possible to have a copy of it, I would like to give it a try.
Thank you
