Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: 4x4 Steel Router
    Feb 2008
    uk
    Smile 4x4 Steel Router
    Hi guys
    here a start on my new 4x4 router, Made from steel box section !
    drivers are gecko g203v,1203oz steppers ballscrews,u bearings for motion.Will add pictures as i go
    Attached Thumbnails Attached Thumbnails 4x4 Steel Router-side_beams.jpg   4x4 Steel Router-gantry_1.jpg   4x4 Steel Router-end_plate_1.jpg
    Apr 2007
    One part completed, and it looks good to me already.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Feb 2008
    uk
    here are the U bearings, These are very well made bearings look and feel very strong, These will be running on 10mm round stainless rod.
    Apr 2007
    Quote Originally Posted by markraws View Post
    Are those 10mm rods going to be fully supported along the length? If not, it won't take much weight load for them to sag.
    CarveOne
    CarveOne
    Feb 2008
    uk
    work progress is a little dusty at the moment, Not ready for painting yet
    the rod is fully supported on 10mm flat bar, And spot welded where needed.If all goes well will mount on table mid week.
    Attached Thumbnails Attached Thumbnails 4x4 Steel Router-rail_sup.jpg   4x4 Steel Router-rail_sup_1.jpg
    Registered LeeWay's Avatar
    Jun 2004
    Thats going to be a nice one.
    Lee
    Sep 2009
    Wow looks fantastic already
    I'm hoping my next machine will be steel. After I finish the first one of course which will be mostly aluminum.
    Feb 2008
    uk
    my first router was aluminium, But was badly built as it was my first router and all!
    my secound router was a 8x4...hehe its a real skill to build so big!!!!
    i only used 1/3rd of it as the linear motion was BAD! i have had a little more time to think and build this one and hope it does what it says on the tin
    Feb 2008
    uk
    ok, Breakout board,motors,power,driver!
    now this is where i need help , Im total rubbish at electronics any help would be very good.Wanting to mount all these in a steel cabinet hope this will arrive in a few weeks, More pictures comming soon
    Attached Thumbnails Attached Thumbnails 4x4 Steel Router-breakout.jpg   4x4 Steel Router-driver.jpg   4x4 Steel Router-power.jpg   4x4 Steel Router-motor.jpg
    Apr 2007
    Ok, that looks like what I was hoping for. Proceed on sir....
    CarveOne
    CarveOne
    Apr 2007
    Good components all.
    I'm using the C11g board for Geckos and home building a box. A more suitable steel box will be found and substituted later.
    CarveOne
    CarveOne
    Feb 2008
    uk
    sounds great, Maybe you could help me set up my controller box ?
    like i say I'm not that great with this sort of thing!
    did a little more on the table today...pfff this thing is heavy, Will add pictures when its finished.
  • Page 1 of 3 123 LastLast
    1. My Steel Frame Router
      By epineh in forum CNC Wood Router Project Log
      Last Post: 07-05-2009, 10:27 PM
    2. New Machine Build- Steel Frame 2' x 4' Router
      By ksubenny in forum Open Source CNC Machine Designs
      Last Post: 08-25-2008, 05:47 AM
    3. Mild Steel on a cnc router?
      By trooper55 in forum General Metal Working Machines
      Last Post: 08-07-2008, 01:43 PM
    4. diy cnc router in steel, any one try it yet??
      By .xXACEXx. in forum DIY CNC Router Table Machines
      Last Post: 10-04-2007, 05:17 PM
    5. Bed Rail Steel CNC Router
      By JackB in forum Open Source CNC Machine Designs
      Last Post: 09-19-2007, 12:03 PM
