Results 1 to 3 of 3
Thread: Cutting Clouds..
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    Cutting Clouds..
    The first time i made some clouds for my son room....but attaching and arranging clouds on the wall was a very difficult task.. The room is still under renovation
    Attached Thumbnails Attached Thumbnails Cutting Clouds..-cl211.jpg   Cutting Clouds..-cl2.jpg
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Apr 2007
    Here is something you can try sometime if you wish to. Behind my living room wood stove chimney is a metal clad heat shield mounted to the wall paneling. When I installed it many years ago it came with high temperature flat black stove paint already applied.
    To give it a bit of color I used my nonexistent artistic abilities to keep it from looking so dull. I found some high temperature white and orange spray paint and added the orange sunrise and cloud. Note that I brought the outline of the cloud "into" the cloud with short black extended lines to make it look more "fluffy". I think you could do that with a V bit to do the cloud outline and the extended lines at 1/2 or 1/3 depth and then cut the cloud free from the material using a straight bit that follows only the outline and goes full depth.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2006
    Pakistan
    wow... carveone..thats beautiful and very good idea to make the Clouds fluffy... I will follow your advice for next cuttings.. thanks for sharing
  1. Modifying point clouds, .stl files...
    By DaveKennedy in forum General CAD Discussion
    Last Post: 01-12-2010, 10:19 AM
  2. Point clouds and Mastercam
    By deon in forum Mastercam
    Last Post: 10-01-2006, 08:18 AM
  3. Software to manipulate point clouds?
    By ckirchen in forum General CAM Discussion
    Last Post: 04-04-2005, 09:07 PM
  4. Point Clouds
    By Freddy in forum Rhino 3D
    Last Post: 11-10-2004, 06:32 AM
  5. Point clouds
    By kdoney in forum Rhino 3D
    Last Post: 05-21-2003, 06:37 AM
