Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #25   Ban this user!
Old 06-13-2005, 09:29 PM
tbenefi33 is on a distinguished road
Hi Dogsione I found a local pc store i might check them out on a dock station.But if i find one i'll let you know.
Old 06-14-2005, 12:12 AM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
well I am sorry about my poor English...well when i was in school i tried to start this kind of project...but all of my professors seed that the ball-screws are the most expensive...is it possible to make one for about 300 €?
How good are you at finding/adapting to surplus parts? For example, the old HP LaserJet printers all had a very useful 100 oz in stepper motor in them, which many of us have used in our own machines.
Your professors were quite correct about ballscrews being the most expensive leadscrews. BUT, the precision of ballscrews is not needed for a woodworking router. Their low friction is desirable, but the increase in cost makes it an unacceptable tradeoff.
Many people use standard threaded rod. Bearing supports can be made from RollerBlade skate bearings -- the ID of the standard bearings is 8mm, which is fit by 8mm threaded rod.
A step up in quality, accuracy, and efficiency can be had by using ACME threaded rod.
You're a mechanical engineer -- I've never met a single ME who did not enjoy recycling discarded parts into usable machines.
(can i use ball-screws of the printers,and their step motors?) Cause i really need about A4 cutting space...?
Refresh my memory on the dimensions of an A4 sheet. Metric is fine. I believe it's a standard piece of typing/copier paper, right?
and i still did not catch how do you control this machines?is there any free software?I really don't need big precision..about .1, to .5 mm( oh and...inches are really com fusing to me) just to cut balsa...and some plywood... maybe Plexiglas...but that is just maybe..the primary function is for cutting balsa...
There are a couple of steps. Do you understand the electronics needed? Basically, what happens is that the software reads an instruction to move the X axis 25mm, and then converts that into the needed number of steps. Out the parallel port come electrical pulses, which are received by a driver circuit. This translates those low level signals into something capable of actually driving the motors.
There are some really good programs to interpret the G-Code. EMC is a free program which runs under LINUX, TurboCNC is a shareware program that runs under DOS, and there are a few really good ones which run under Windows for various prices.
PS I am sorry.y if i ask questions that are already answered somewhere in this forum...but this forum is huge...
You're right. This is an amazing site, with an enormous amount of information. It's actually difficult to find the necessary information, without dedicating a week or two to actually reading everything on it.
-- Chuck Knight
  #27   Ban this user!
Old 06-14-2005, 12:05 PM
Sturmer is on a distinguished road
Well i was thinking something like that,well all of my stuff that i made/make is made from scrap...very few things i buy...well i am student which is working to pay of his intuition..and life costs(i am from pretty poor family)but my curious nature is stronger then my low budget so..
Yes it is standarad printig paper size...
Yes i do understand the electronic part of the machine...i had few of my own concepts but i have terminated them because i did not know how to make software to control the machine... and i was afraid of the mistake it would made....and the software i used in school is simple(cad like)...is there free software which is CAD like?Or which uses DXF formatted drawings?Or that compiles the CAD drawing into code?
Originally Posted by tbenefi33
hi strumer well right now i'm on hold on my project cause it summer time here..lol i have every thing done and all i needs is the electronics and flang bearing So far i got all most $400.00 in the project .Its safe to say you'll probley spend around $600.00 to a $1,000.00.Shop around and look for the cheaper price I'm still looking for some stepper moters.
well if i use the stepper motors i got from the printers(or some where else) and if i scrap for almoust all the solid stuff,and buy just the electronics what whuld be the price..?
Old 06-15-2005, 12:16 AM
chuckknigh's Avatar
Gold Member
Can you build the electronics, or must you buy them pre-built? I don't know what things cost in your part of the world.
There is a kit in the US, called PICStep, which is only about $75 for a 3 axis setup. BUT, it's a kit. Other well known kits are Xylotex and HobbyCNC, both of which have excellent track records.
I doubt the electronics would cost you more than $100US, if bought in the United States.
You said you're a student. Does your school have an electronics program? Might one of the other students or maybe one of the more open-minded teachers be able to help with the electronics? There are super-simple stepper driver circuits available, on the web...not exceptionally efficient, but the cost is definitely right.
Stepper driver circuits are a fairly common project, in many electronics courses.
-- Chuck Knight
  #29   Ban this user!
Old 06-15-2005, 12:25 AM
I"ve been eyeballing the kits on hobby cnc also hard alot good stuff about um some said they where eazy to put toghter not sure what the price is on them.I'll have to check the site out i havent been on there awhile.
Old 06-15-2005, 12:30 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I use the HobbyCNC board the three axis is 79.00, yes is very easy to put together with his instructions that are included and he also has the yahoo forum that is helpful. I give it two thumbs up...
Old 06-15-2005, 12:51 AM
chuckknigh's Avatar
Gold Member
Noone *likes* to pay full price for anything! And, happily, in this hobby there are almost always other options.
Getting creative with the parts is half the fun of building these machines!
It's a multi-step process using the free tools, but it works really well.
Step 1, draw your part in a CAD program, save it as a DXF file.
Step 2, use a CAM rogram to convert it to G-Code. This is a type of programming language that syas things like move the X axis +25mm, and move the Y axis -47mm.
Step 3, run the G-Code through a controller program like TurboCNC. http://www.dakeng.com is their URL, I think. This program turns the instructions in G-Code into the needed pulses to control *your* particular setup. You define that 200 steps (pulses) = 1 rotation, and each rotation is 1mm...that sort of thing. It does the calculations, and outputs the right stuff through the parallel port of your computer.
-- Chuck Knight
  #32   Ban this user!
Old 06-15-2005, 04:20 AM
Cool
Originally Posted by chuckknightep 2, use a CAM rogram to convert it to G-Code. This is a type of programming language that syas things like move the X axis +25mm, and move the Y axis -47mm.
Step 3, run the G-Code through a controller program like TurboCNC. [url
http://www.dakeng.com[/url] is their URL, I think. This program turns the instructions in G-Code into the needed pulses to control *your* particular setup. You define that 200 steps (pulses) = 1 rotation, and each rotation is 1mm...that sort of thing. It does the calculations, and outputs the right stuff through the parallel port of your computer.
-- Chuck Knight
i know the G-code in high school i had few exams in it....and i used it for couple of my home made projects...so i know how to use it...i am now on collage(i used machines in highschool...i have high school degree in mehatronics this is how education works in Croatia)
Is there any free shematic of full 3axis controller?(part list,shematic and pcb board pictures) so i can buy part by part...
( resistor by resistor )
And i am definitively not interested in buying complete kits...it is just not fun...
hm...i have a another problem...the size and noise...i will probably use it in my room...so...i have pretty old and grounch neighbors...
i have contacted my old professor,and i will probably have the access to the milling machine so i could make all the parts on it...
and i have a another question,what kind of cutting tool i will need to cut balsa?! High speed drill?With a milling head?
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 09:04 AM
Confused about CNC software samualt General CAM Discussion 22 06-30-2005 08:18 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
FeatureCAM Expands Product Offering with Machine Simulation CNCadmin Product Announcements & Manufacturer News 0 01-21-2005 06:58 PM
