Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 03-01-2005, 07:31 PM
kra kra is offline
kra is on a distinguished road
my cnc router
here are a couple of pics of my router
made almost entirely from scraps, salvaged parts (except for Geckos)
Even computer was free salvage (1GHZ)
will cut 24"x40"
waiting on 3rd Gecko to finish up
Randy
Name:	Resize of CNC.JPG‎
ID:	5752   Click image for larger version
Name:	Resize of CNC2.JPG‎
ID:	5753   Click image for larger version
Name:	Resize of Power supply.JPG‎
Old 03-01-2005, 08:08 PM
quadmasta is on a distinguished road
I really like how you finished the table. It looks really good to me
Old 03-01-2005, 08:19 PM
trubleshtr is on a distinguished road
Nice job. Your a guy after my own heart, I scrape beg and borrow to build my current cnc project.
Are you going to enclose the power supply after the 3rd geko arrives?
menomana
Old 03-01-2005, 08:31 PM
kra kra is offline
thanks guys
Yes I am going to house the power supply
I still need limit switches and need to clean up some wiring, etc.
now I have to figure out how to use it
I have purchased Mach2 and am playing around with it some
I have made a few cuts with it
power supply is 48v (rewired transformer)
steppers are nema34. 180oz.-in. y and z, 370 on x bipolar series wired
I had a lot of help from reading posts on this forum!
Randy
Old 03-08-2005, 09:55 AM
erikkate is on a distinguished road
Can you give us a detailphoto of your bearingdesign?
Would help me a lot
Nice looking machine you've got there!
Old 03-08-2005, 02:26 PM
kra kra is offline
I will take some closeup pics when I get a chance
I used an old drafting machine from an old desk I no longer use for the x axis
beefed it up a little
the y axis is black pipe over drill rod with homemade oillite bronze bushings fitted and a nut over the end that can be adjusted to tighten the bearing as it wears
the z axis is rods from old printers with oillite bronze bushings fitted
a real hodgepodge of whatever I had laying around but it does work
some parts are cast aluminum from scraps, some are steel welded up, some are wood
Old 03-14-2005, 09:08 PM
kra kra is offline
my first 2 1/2 D routing
cut from 3/4 expanded pvc
next project will definately be vac. hose attachment!
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 11:12 PM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 05:46 PM
CNC Router Taper Machine hadjcues DIY-CNC Router Table Machines 8 03-23-2005 06:02 PM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 12:43 PM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 11:18 AM
