Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-28-2005, 01:35 PM
ljoe1969 is on a distinguished road
Here is the DIY I built.
I built this last summer. Been trying to get the bugs out ever since. The gantry rocks while moving. I can get only 20 inches per min with it. It has a foot print of 48" x 36" lot less cutting area. I dont suggest building one like this.
Name:	router1 small.jpg‎
ID:	5678   Click image for larger version
Name:	router2 small.jpg‎
ID:	5679   Click image for larger version
Name:	router3 small.jpg‎
Old 02-28-2005, 01:45 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Very nice, good use of bearing..
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 02-28-2005, 01:59 PM
JavaDog's Avatar
JavaDog is on a distinguished road
Have you thought about ditching the L-Channel and going with the traditional gas-pipe. Looks like you could do that without too much modification. Might be an easy way to gain some stability and eliminate the gantry rocking problem.
Old 02-28-2005, 02:53 PM
Currently my plans are to make a new CnC that is 11" x 17" cut area. I think I tried to make too big a machine on my first try.
Old 02-28-2005, 04:42 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I also use the v bearing on angle iron method and it works well. Shopbot also uses this method. Can I suggest a few alterations that will help with stability.
The gantry should be driven on both sides by the one stepper and a drive shaft across its length. This will remove the racking problem. You should also increase its stability as shown below.
You mention that you are considering to make a new machine. Can i say that you are so close with this one that to modify it would be far easier than starting again. The only other mod I suggest its to raise the height of the rails and reduce the height of the gantry sides. If you look at the shopbot you will notice this is how they achieve better stability.
EDIT: the rails can be supported along the full length. This will also help with stability too.
Open Team Cheap DIY CNC Moving Gantry Router pminmo DIY-CNC Router Table Machines 94 08-19-2007 02:59 PM
Would like to built a twinn... need help to start. CrazyRonny I.C. Engines 5 03-09-2005 01:09 AM
Anyone built their own CNC Lathe (DIY) MrBean General Metal Working Machines 3 03-02-2005 06:56 PM
my DIY CNC progress in reverse slp_prlzys DIY-CNC Router Table Machines 1 11-15-2004 12:44 AM
Any DIY metal mills being built marx911 General Metal Working Machines 15 11-11-2004 11:19 PM
