Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-22-2005, 09:26 AM
limbo is on a distinguished road
Oh no, not another router!
After playing around with my current router for over a year I think I've gathered enough excuses to start building a new (3rd) one. This one should have:
-larger travel: 24" by 48" to fully access standard plywood panels.
-vacuum hold down for those bendy balsa sheets that follow your bit wherever it goes.
-rack & pinion on X and Y
-supported rails on X to finally be done with the sagging.
-a nicer color (hey, I do need excuses)
Although it will probably not be the fastest build, I thought it would be nice to start a build log. All comments en suggestions welcome!
Here's a pic of the frame being assembled and result:
greetings,
John
ID:	5525   Click image for larger version
Old 02-23-2005, 01:42 AM
jimini is on a distinguished road
I see by the picture that you're starting at a good, young age. lol
Old 02-23-2005, 06:58 AM
Yes, but my daddy is helping me a little.
Here's a bit more progress and a sketch of the gantry. The steel tubes that serve as X-guides are bolted down every 20 cm's. After having screwed together the frame Ynneb's saying "more bolts than the Sydney harbour bridge" popped in my mind a few times. I can imagine his complete machine must have a factor more...
John
ID:	5549   Click image for larger version
ID:	5550   Click image for larger version
ID:	5551   Click image for larger version
Old 02-23-2005, 09:24 AM
*Registered User*
lurch is on a distinguished road
A very nice start!! Simple, and clean, a good design. One question what keeps the x axis trucks from lifting under a downward load?
Old 02-24-2005, 05:37 AM
The only thing that keeps the gantry down is gravity. The gantry on my current machine weighs around 30kg, so I'm expecting this one to be around 50kg. I'm sure my router will not be able to lift that. (In fact, I hope those cheapo skate bearings will hold up.) The bearings are spaced far apart (28cm) while the gantry is as low as I could get it. The centre of gravity is mid betweed bearings and only some 12cm above the rails, so that a sudden stop after a rapid move will not cause the gantry to fall over.
John
Old 02-24-2005, 12:54 PM
Hobbiest is on a distinguished road
John
unless you got the cheapest bearings money can buy (which they don't look like) they should be fine. A skateboard uses 8 bearings, and I have known skaters who weigh 300 to 400 pounds!
Stop talking about it and do it already!!!!!
Old 02-25-2005, 11:29 AM
They are labeled ABEC5-608something. I dont think they are very good quality though. Brand new out of the box they have some play in them. Not side to side, but I can vary the angle of the inner ring w.r.t. the outer ring a bit by taking the bearing in one hand and holding the inner ring between thumb and finger of the other hand. Is that normal? They don't seem to have any play in axial or radial direction.
John
Old 02-25-2005, 02:37 PM
cnc2k is on a distinguished road
Anyone know best why to drill linear holes a steel rod?
Old 02-25-2005, 08:20 PM
Ferenczyg is on a distinguished road
John
IF I am not in a mistake skate bearings are from abec-1 to abec-7 in uneven numbers, being better for higher number so yours are at least on the good side
/F
Old 03-02-2005, 05:25 AM
Hmm, I found a few old abec3 bearings in my scrap box and they have no play at all. Now I know why these abec5's were so cheap.. Oh well, I'll look at it from the positive side and say that some play is necessary to cope with misalignment in the bearing trucks.
Its too cold in the garage to start longer projects like routing the gantry side panels, so I did a few quick jobs. I made some U shaped extensions that will increase the Z-axis stroke, and a quick test to see if I could make the gear pulleys myself. I'm amazed at how well they came out. The part is accurate within 0.2mm! The material is Trespa. Very strong and weather proof but easyer to route than aluminium.
John
ID:	5774   Click image for larger version
ID:	5775   Click image for larger version
  #11   Ban this user!
Old 03-02-2005, 08:37 AM
Mike F is on a distinguished road
John,
What is Trespa? I have not heard of this material but it sounds interesting. Is this a trade name in the Netherlands?
What size are the pulleys and what belts are you using with them?
Sorry for all the questions but this is one of the great things about this forum - the fact that you can glean so much information so quickly and pose many questions easily.
Good looking machine by the way.
Mike
  #12   Ban this user!
Old 03-02-2005, 09:40 AM
Trespa is the trade name. In the Netherlands it is commonly used in house building, to finish the sides of the roof and as panels below windows and so on. It doesn't need to be painted and will last forever, even in our climate. I've heard that it consists of layers of paper, drenched in resin, pressed together under high force at high temp. It looks a little like the old brown PCB boards, but I think Trespa is more dense and heavyer. Great stuff.
The pulleys are for 1/5" pitch toothed belts (5.08mm pitch), 9.5mm wide. There is 40T on the pulley which is 64.6mm (~2.5") dia. The stepper has a 10T pulley giving 1:4 reduction for the pinion drive.
John
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 11:12 PM
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 02:17 AM
Quick built router CNC Darren DIY-CNC Router Table Machines 10 06-05-2005 09:09 PM
long term stability of wood framed router dave925 DIY-CNC Router Table Machines 17 05-06-2005 12:33 AM
my new longbed router cncspear DIY-CNC Router Table Machines 16 10-15-2004 09:36 PM
