| CNC Wood Router Project Log Post your CNC machine building log here only. |
#73
Viper, you take after my own heart. I like seeing pics too. Here is a link to a photo. http://www.leestyron.com/cnc/big1.jpg Here is a video clip that is rather large. Just to hear the steppers. These are running at 60 IPM. Don't even click the link if you are on dialup. It's a flash file and took me about 20 seconds on DSL. http://www.leestyron.com/cnc/cuttyshark.swf I have another photo's of the parts for my mill that I won on Ebay. I am liking these. http://www.leestyron.com/cnc/millpics/slide4.jpg
__________________ Lee |
#74
So where can a person buy the cam-clamp thingies (y'know - the blue lever do-hickies in your photo's) ?Cheers! |
#77
#78
| Okay, Guys. I have had to use a belt drive on the x axis after I found out that the little Lovejoy coupling just wasn't beefy enough and also allowed too much backlash. The belt and geras are because once I installed a solid coupler I made of brass, I had some issues with the motor alignment to the screw. I turned these screws myself and they aere not perfect. Belt and cogs should take care of this issue and let me speed it back up some. The pulleys I got are 14 teeth on the motor side and 21 teeth on the screw side. Isn't this a 1 to 1.5 ratio? I currently have the motor set to 8000 steps per inch. Would the new configuration be like 12,000 SPI? It just can't be that simple can it?
#80
| Thought you might be interested in an upgrade I was forced to make this past week. I was having some computer issues with the case I built. I have had another complete drive system sitting here waiting until I get time to finish my plasma cutter. You can see that thread here. http://www.cnczone.com/forums/showthread.php?t=34626 Here is an image of the basic machine controller and a closeup of the Gecko's. Anyway. I was really amazed at the difference between the two control systems. I was getting 50 IPM with the Xylotex and I can go over 300 IPM with the Gecko's. Wow! What a difference. 28VDC with the Xylotex and 62vdc with the Gecko 201's. These are direct drive. I bought three 203v's yesterday as a backup. I did figure out what was messing me up on the first computer. It was a bad ram chip. I replaced the bad one and it is good to go now as well. After seeing the gecko's in action, I am probably going to sell the original as a plug and play setup. Computer, PS, Xylotex 3 axis driver, fans, case, motors and all wiring. The ram chip is the only thing that has ever failed on it the way it is setup, so I am pretty confident that it would make a good starter system for someone and save quite a bit of time and frustration. You may eventually see it on Ebay. If someone here is interested, just make an offer.
#81
| A little video update. Had the video for a little while now, but just finally uploaded it to YouTube.
