Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-11-2005, 11:40 PM
eqreservoir is on a distinguished road
Thumbs down Want to Build a Wood Router
I've been collecting a few parts so I can build a CNC wood router. I've been reading the post in regards to this new found (for me) obsession. I now have my first (of many) question.
What I found at the goodwill today was a sharp copier SF2022 for $20.00. The copier, a floor type, stands about three foot and is
3ft x 2ft and has a collator and 3 paper drawers. Would this be a good source for steppers and parts for a DIY CNC router?
Any help will be appreciated.
Thank you. HTj
Old 02-12-2005, 12:14 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
They may be OK depending on what you plan on cutting, those stepper motor may not have much torque for you.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 02-12-2005, 12:54 AM
Thank you for your answer. I was afraid that they wouldn't have the torque for a router. That's why I thought I would ask before I bought.
I plan on building a moving gantry router with a cutting surface of 48" X 36". the table frame out of steel tubing and the gantry using the concepts in JRGO plans on this site.
Thanks again.
HTj
Old 02-12-2005, 01:21 AM
CNC Darren is on a distinguished road
You might want to take a look and see if that copier has a document feeder on top. I have pulled apart some older Sharp copiers (not sure of the model number off hand) but some use dc brushed motors (sharp 3062 I know for sure) or steppers. The steppers that I pulled from one of the copiers is rated at 118 oz/in and I am currently using them on my JGRO router.
Darren
Metal With a Wood Router??? Sanghera DIY-CNC Router Table Machines 16 03-07-2008 01:44 PM
Want to build CNC Router for routing 3/4" MDF and solid wood Darren_T DIY-CNC Router Table Machines 28 10-15-2006 09:31 PM
long term stability of wood framed router dave925 DIY-CNC Router Table Machines 17 05-06-2005 12:33 AM
Prefered Plans, Kits with suport for wood router Ol'Dusty DIY-CNC Router Table Machines 0 10-13-2004 07:13 PM
