Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: Getting my Router up and running
  1. #13
    Mar 2003
    Shelby Twp, MI....USA
    Are you going to keep the 10 tpi screws?
  2. #14
    Jul 2008
    Gerry,
    Re. lead-screws, at this point I would say yes unless there is a really compelling reason to switch.
    ivor
  3. #15
    Mar 2003
    Is 2-3x more speed compelling enough?
  4. #16
    Jul 2008
    Well, if I can get 500-600 IPM out of my current lead-screws with the right motors I would say no.
    Ivor
  • #17
    Mar 2003
    You'll be lucky to get 1500 rpm, which would be 150ipm with 10 tpi screws. Most consider 1000 rpm very good for a stepper driven machine.
  • #18
    Jul 2008
    Ah well, back to the drawing board to see what I can do.
    thanks for all the help,
    I'll let you know how I get on.
    Ivor
  • #19
    Mar 2003
    Also, consider that the screw may not be able to rotate that fast without whipping a lot. A lot of people find that screw whip is the limiting factor in the speed they can attain.
  • #20
    Jul 2008
    Gerry,
    I think I'll stick with the 10TPI for now, just to get some experience with the machine and then I can upgrade to what makes sense at that time.
    I did think about using a 2:1 gear set-up but I take your comment about whip. I have built an RC airplane using a long shaft drive to the propeller and shaft whip was a big issue in the design.
    At this point I want to get a good reliable machine making sawdust and move up the learning curve a bit.
    More to follow when I start cutting wood!
    Ivor
  • Page 2 of 2 FirstFirst 12
    1. Mini router up and running
      By chuck99z28 in forum DIY CNC Router Table Machines
      Last Post: 10-25-2008, 09:19 PM
    2. Running Mach3 with a Step four router
      By B-Sure in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 10-07-2008, 11:09 PM
    3. 5AX 500 anyone running one?
      By BJ-DEKA in forum Bridgeport and Hardinge Mills
      Last Post: 12-27-2007, 11:10 AM
    4. Running hot, really, really hot
      By imagineer in forum Stepper Motors and Drives
      Last Post: 01-18-2007, 09:51 AM
    5. Up and running!
      By maxxgraphix in forum DIY CNC Router Table Machines
      Last Post: 03-16-2005, 08:10 AM
