Page 4 of 4 FirstFirst 1234
Results 37 to 40 of 40
Thread: The Elite Modder - CVRIV_CNCRTR_001
  1. #37
    Feb 2005
    How big of a working area do you need? is 4ft x 4ft enought? If so you could build a Joes 4x4 alot quicker then a mechmate.
    http://joescnc.com/
    I would have built one of those if it had been around when I started building my CNC router.
  2. #38
    Mar 2009
    I need a 4 x 8. This just isnt for hobby. I doing this for money too. Mostly for money. So I need to be able to stick a 4 x 8 sheets right into the machine.
  3. #39
    Feb 2005
    then it sounds like the mechmate is the way to go. I hope that you put up a great build log for that machine here. I have not seen a really good one for the mechmate.
    From what I have seen about building that machine, you might want to look into using actual v-rail instead of spending the hours it takes to make the v-rail yourself.
  4. #40
    Mar 2009
    Quote Originally Posted by nlancaster View Post
    Yea im just going to follow the plans exactly. I will put up a reall good log here. I think I will go ahead and model it first using the plans. This way I know excatly what needs to be done when I do get the chance. I have time before I will actually be able to start building it because I haven't got my house yet with the garage. That will happen in the next few months.
  1. The "Elite" CNC design
    By RiseUp in forum Open Source CNC Machine Designs
    Last Post: 02-04-2009, 07:57 AM
