Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #61   Ban this user!
Old 03-26-2006, 05:50 AM
JavaDog's Avatar
JavaDog is on a distinguished road
Originally Posted by victorbl
The router does have a 3.5" diameter. I'm starting to notice that there are alot of routers out there with that dimension. I realize that the shape isn't perfect for everyone's design, but it's sometimes better than starting from scratch!
I am using the same exact router as the spindle for my machine. Oh, these templates are going to be handy! You just saved me some work...
BTW - How do you like that router?
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 03-26-2006, 09:39 PM
spalm's Avatar
Gold Member
spalm is on a distinguished road
Nice looking machine,
I see you separated the two router mounts. I did the same on my first machine. I found it allowed a little flex. On my second machine, I basically glued them together and added a triangle support. This gives me more adjustment to move the router up and down, and a bit more strength, but I found that I can mount the router with a bit of a tilt, and takes a bit of fiddling to get it straight up and down.
Just thought I’d throw in my $.02 worth.
Steve
Cut the MDF to create an CNC machine. samsagaz WoodWorking 6 07-22-2008 11:20 PM
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 09:04 AM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
My CNC Machine and Questions Davedbq General Electronics Discussion 2 01-22-2005 09:14 AM
MDF Machine - Cut Aluminum? JavaDog DIY-CNC Router Table Machines 7 11-10-2004 01:05 PM
