Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 01-02-2005, 05:17 PM
Wanna be
Hack is on a distinguished road
Better late then never!!
Well folks - Santa was pretty good to me this year and brought me this neat little thing called a digital camera. Yes!!!!
Now I can finally share some pics with you folks of what I am building. This is my router with a cut size of about 32 x 48 x 6" . I wanted to be able to do 1/3 sheet of plywood. This is just a prototype and I already have plans to do a second / better one, but wanted to see how this performs as I may sneak a mill in before the next router.
I will use a PC Laminate trimmer for the spindle. Primare cutting will be done on solid wood and mdf. I haven't mounted the router yet obviously, but it is sitting in the garage waiting.
I just received some couplings from HobbyCNC last week (great service by the way) and will mount the steepers next (276 oz/in from Automation Direct)
Name:	CNC Pictures 001.jpg‎
Check out what I am working on at www.routerbitz.com!
Old 01-02-2005, 05:20 PM
Wanna be
Picture of the z axis
Z axis complete with drawer slide linear guides (read freebeee!!)
Name:	CNC Pictures 003.jpg‎
Old 01-02-2005, 05:24 PM
Wanna be
Close up of how the x and y axis are done
Simply some aluminum angle with Abec bearings - seem to work very nice.
Name:	CNC Pictures 004.jpg‎
Old 01-02-2005, 05:26 PM
Wanna be
Lead Screws
1/4 - 20 threaded rod (this will be the first thing to be replaced cause it will make it very sloowwwww) for the lead screw with some more angle and 1/2" HDPE drilled and tapped.
Name:	CNC Pictures 002.jpg‎
Old 01-02-2005, 05:28 PM
Wanna be
Steppers
Stepper motors from Automation Direct - 276 oz/in Nema 23 Bipolar
Name:	CNC Pictures 007.jpg‎
Old 01-07-2005, 09:06 PM
Wanna be
Need help finding a power supply
I have pretty much decided on the xylotex for my machine but need a power supply that can work with that board and my motors. Can anyone point me to one that they have had success with?
TIA
Old 01-07-2005, 09:09 PM
Wanna be
Forgot to mention
Those motors are 2.8A per phase approx 30 Volts
Old 01-07-2005, 09:24 PM
ger21's Avatar
http://www.mpja.com/productview.asp?product=12424+PS
http://www.mpja.com/productview.asp?product=15366+PS
A lot of Xylotex users use the power supplies from MPJA. You want to get at least 24V, and no more than 28V. And probably 6a or more.
You can get something cheaper from Ebay, if your patient. I got a 24V 12a for $5. I took a quick look, though, and didn't really see anything right now.
Btw, those aren't 30V motors. Automation Direct doesn't provide that info, but it's most likely 3-5V.
Old 01-07-2005, 09:30 PM
BobLWeiss is on a distinguished road
I like your design! Nice work.
Did you use angle aluminum on both the top and the bottom for the Y axis? How many bearings do you have on the X and Y axis each? I never thought of using angled aluminum that way...I might have to make another machine!!!
Take some more pictures..
Bob
Old 01-07-2005, 10:45 PM
Wanna be
Bearing Setup
I used angle for both the top and bottom on both the x and y axis. 8 bearings per axis - locks it in good. Was gonna do the same for the z but clearance was a problem. A pretty cheap method for longer axis if you don't need a lot of accuracy.
Automation Direct sells a 32 voly power supply that they reccommend for the above motors
http://web3.automationdirect.com/adc...r/STP-PWR-3204
That is why I assumed that they are around 30 volts. Am I wrong?
Dan
Old 01-08-2005, 12:43 PM
ger21's Avatar
Dan
Yes, your wrong.
The reason their supply is 32V is because that is what works best with their drives. To get any speed out of steppers, you usually need to supply at least 5x-to 10x their rated voltage. So most likely they are rated at a lower voltage. I *think* you can determine the voltage be measuring the coils resistance.V = amps x resistance.
But, like I said, to keep your Xylotex safe, use 28V as a MAX.
Old 01-09-2005, 08:52 AM
jgro's Avatar
Gold Member
jgro is on a distinguished road
This is the power supply that I'm using. Works great. http://www.allelectronics.com/cgi-bi...465&type=store
jgro
Free Router plans! and Discuss it here. CNCadmin JGRO Router Table Design 374 07-26-2011 07:02 AM
Take a look at this Beauty ...and its never to late to learn Al_The_Man I.C. Engines 6 07-12-2005 07:38 AM
Flashcut to Geckodrive 210 whiteriver FlashCut CNC 17 02-22-2005 10:30 PM
Point Clouds Freddy Rhino 3D 6 11-10-2004 06:32 AM
New Onecnc user!! smitty OneCNC 117 08-12-2003 08:44 PM
