Results 1 to 12 of 12
Thread: CNC Router Hybrid Wood/Steel
    Registered Grandad's Avatar
    Feb 2006
    pORTUGAL
    Hi Guys, After the success of my first small machine I thought you might like to see the progress on mark2. It has a cutting area of 60" x 30", Twin leadscrew X axis drive (2 x 400oz steppers, that gantry is heavy). I'm about 60% into the build and making steady progress
    Attached Thumbnails Attached Thumbnails CNC Router Hybrid Wood/Steel-mark-2-1.jpg   CNC Router Hybrid Wood/Steel-mark-2-2.jpg   CNC Router Hybrid Wood/Steel-mark-2-3.jpg   CNC Router Hybrid Wood/Steel-mark-2-truck1.jpg
    CNC Router Hybrid Wood/Steel-mark-2-endplates.jpg
    Registered Weldtutor's Avatar
    Oct 2005
    Nice looking steel construction!
    Interesting bearing systems on both X & Y axis that should work well.
    Feb 2006
    pORTUGAL
    Thanks Weldtutor....
    Feb 2006
    pORTUGAL
    Need Help, Twin X axis Drive
    I am building router using twin acme leadscrews to drive the X axis coupled to twin stepper motors. The two motors are slaved together in Mach 3 and I will be using a Gecko G540 drive. I am having nightmares about the motors not running in sync and causing problems withe gantry. Can anybody out there give some input as to what problems I could possibly have...Thanks
    Apr 2007
    There are some discussions about how to approach this in the stepper motor area of the forums. I have not done it yet, but I think that it is a matter of using some of the functions in mach III to pull it off.
    I am just curious - how stiff are those Y rails ? That is where I see the risk of a "non stiff" machine. (not that my build is even close to your progess)
    Feb 2006
    pORTUGAL
    Hi Harryn, Thanks for the info on stepper area, i'll check it out. This machine design is based on an earlier machine I built which was very succesful. The Y axis rails are 33mm heavy wall Stainless. The complete Y assy seems to be very rigid but only time will tell. How is your build, any pics?....regards Rod
    Apr 2007
    Meanwhile, I am furiously building away on a machine that will use dual stepper drive motors on the X axis in the hopes that it is resolved soon. I don't have any plans to sync the lead screws with a timing belt or chain and hope that I don't have to.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2007
    Quote Originally Posted by Grandad View Post
    Yes, that will certainly work as support rail.
    My "build thread" so far is mostly a parts list collection. There are some pics in post 58 of my "plywood aided design" version. Basically, I decided to stop drawing pictures and build up a plywood prototype as a learning experience, them evolve it into something hopefully useful.
    (edit - added link) http://cnczone.com/forums/showthread.php?t=38940
    In terms of the "nightmare questions", I guess the thing to watch for is the make sure each stepper can provide the full torque required, as opposed to thinking the load is now divided by 2. As the router moves around on the table, the load will shift with it. I am guessing since you have already built one, you already knew this.
    Feb 2006
    pORTUGAL
    Update on wood/steel hybrid machine
    Been busy on the lathe for a couple of days after long delay, but back on track again. Z axis is almost done as well. Will post more pictures when Z is mounted
    Attached Thumbnails Attached Thumbnails CNC Router Hybrid Wood/Steel-stepper_mounts.jpg   CNC Router Hybrid Wood/Steel-mk2_small.jpg
    Feb 2006
    pORTUGAL
    Z-axis going together
    Finally got the Z-axis looking as though it might work, on to the dreaded twin drive X-axis. Still having nightmares about missing steps on X, gantries going sideways etc. The only way to find out is to try it, fortunately I have great faith in Mach 3 and the gantry rolls like a dream. I would love feedback from anybody running twin X's....Rod
    Attached Thumbnails Attached Thumbnails CNC Router Hybrid Wood/Steel--date-16.02_090002-web.jpg   CNC Router Hybrid Wood/Steel--date-16.02_090003-web.jpg
    Feb 2006
    pORTUGAL
    oop's posted wrong pictures
    Attached Thumbnails Attached Thumbnails CNC Router Hybrid Wood/Steel-25th-march-z-axis0002web.jpg   CNC Router Hybrid Wood/Steel-25th-march-z-axis0003web.jpg
    Sep 2007
    Grandad,
    Look at Joes 4x4. There are dual motors on X. When frst built, he used a timing belt on pulleys on the back axel of the X motors. I think some of the current builders may have abandoned the belt as not needed, since the software sync seems to work well. Add the belt if you are nervous.
    1. Steel Gantry Wood Router
      By gavztheouch in forum DIY CNC Router Table Machines
      Last Post: 09-01-2012, 01:37 PM
    2. Plans for Joe's Hybrid CNC router?
      By jeffmorris in forum Joes CNC Model 2006
      Last Post: 08-12-2008, 07:05 PM
    3. Build Thread- Steel Frame CNC Wood Router
      By CNC Rocks in forum DIY CNC Router Table Machines
      Last Post: 08-11-2008, 12:13 PM
    4. First Router steel & wood.
      By thetrick in forum CNC Wood Router Project Log
      Last Post: 04-15-2008, 10:00 PM
    5. Milling Steel with a Retroed Wood Router
      By whiteriver in forum Commercial CNC Wood Routers
      Last Post: 07-08-2005, 07:27 AM
