Is the acme rod "fixed" at both ends... if so undoe one end and let it float. You should be ok Providing you have precision alignment on your "rails" and between your 2 rails.
You might want to look at your whole set-up for parallel otherwise. Quick/dirty cheat way is to loosen off one rail slightly and let the "machine" put it where it wants to go if parallel is your issue.
LinkBack URL
About LinkBacks
