Page 271 of 274 FirstFirst ... 171221261268269270271272273274 LastLast
Results 3,241 to 3,252 of 3284
Like Tree5Likes
Thread: CarveOne's Work Table CNC Router Build
  1. #3241
    Jan 2008
    canada
    Quote Originally Posted by CarveOne View Post
    So you signed up? Do they want more info on you than a username and password?
    CarveOne
    I think they need an email too. It didn't strike me as too invasive. I use it to host my WarpDriver downloads. PaulRowntree.weebly.com
    Colten : How do you get a DNS entry for your Linux box? Do ISP's generally allow clients to set up their own Apache servers? This sounds like a good route if the volume is not an issue.
    Cheers!
  2. #3242
    Silver Member cd_edwards's Avatar
    Sep 2011
    canada
    I have 2 static ip's from my provider. I pay a little extra for them. I've never asked and they've never complained about me running server's from my 2 ip's. One ip is my home network which has some redirection going on to port forward to my linux box any port 80 requests. The other ip, I've used for a webserver for my RC club hcrcc.org. I also have another host setup on there using apache's virtual hosting for a RC helicopter event our club holds every year. That's at shag.heliaddiction.com.
    AS far as getting that DNS entry, you only need to setup a hostname on godaddy, and the setup the A address to point to your static ip address. It's very simple todo as long as you have static ip's.
    Colten Edwards
  3. #3243
    Apr 2007
    Quote Originally Posted by cd_edwards View Post
    Think I'll just figure out some web stuff and host it myself on my linux box. www.thebadbeaver.com sounds appropriate for a cnc router website
    Make sure it has about 100 gigaterabytes of storage to start with. We'll use that up in short order. I know nothing about setting up a website.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  4. #3244
    Apr 2007
    Quote Originally Posted by PaulRowntree View Post
    Cheers!
    I could get a free email account for use with that site only. Thanks. I had never seen a reference to them before.
    CarveOne
    CarveOne
  • #3245
    Aug 2007
    Whoosh, I'm tired.
    First off, I know this is may be considered "old" for a forum, but...
    I (huff)
    have just read the entire thread...
    Start to finish... page 1 to 271... 3244 posts.
    Took me two weeks.
    As soon as I have a little 'extra income' I will be aquiring the parts for a build similar (but probably much smaller) than yours, CarveOne. I have obviously been very entertained by this build and I am impressed with your work.
    I have been a LONG time lurker of CNCzone and now I think i need to take a break after this! I could have had an entire desktop CNC machine built in the time I have spent reading this.
    Brandon
    P.S. I have never seen so many calendars in one place!
  • #3246
    Apr 2007
    Thanks for making my cap feel much smaller. I hope the entertainment was worth your time. Hurry up and build something.
    I tend to be um, "wordy" too. If you haven't seen enough calendars look at my current project in my CarveOne's steel channel build log. I'll put them anywhere on a dare.
    CarveOne
  • #3247
    Jul 2012
    Unhappy
    For those of you who are looking for Arbo's original Mayan Haab calendar DXF file, it can be obtained from fastpcuser's direct download link. I hope Arbo doesn't mind. There have been a few new requests for it since I posted the last images of one I made. Get it while you can.
    Thanks fastpcuser!
    CarveOne
    It's gone
    Wolffie
  • #3248
    Apr 2007
    Quote Originally Posted by Wolffie View Post
    It's gone
    Wolffie
    Not to worry, you can find it in my website's Download folder. The first file.
    CarveOne
  • #3249
    Jul 2012
    Thank you C1
    Do you know where I can find the Aztec one?
    The picture I have is rather blurry
    Wolffie
    Bet you didn't know us Queenslanders are called Banana Benders.
  • #3250
    Apr 2007
    Thank you C1
    Wolffie
    Try this download link:
    http://www.cnczone.com/forums/attach...6&d=1343221731
    It is posted in one of my other build logs, CarveOne's Steel Channel Rebuild. If you open the zip file, then open the Top Panel file, click on the 6" Aztec calendar centerpiece, you can then export the calendar as a separate dxf file. Then you can import that to a new Vcarve Pro file and scale it to any size you need. Or you can just copy the centerpiece and paste it directly into a new project in VCP.
    I also posted the file over in the Vectric forums where I have been showing the Paradise boxes I've made.
    CarveOne
  • #3251
    Jul 2012
    Thanks so very much C1
    Cheers
    Wolffie
  • #3252
    Apr 2007
    Cheers
    Wolffie
    You're very welcome Wolffie. Glad to help. After you scale it up check it for open vectors. I haven't had any problems with it in Vcarve Pro or Aspire, but it can happen, especially if the Join Vectors tool's default resolution is set to a really small value.
    CarveOne
  • Page 271 of 274 FirstFirst ... 171221261268269270271272273274 LastLast
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. CarveOne's Solsylva 25x37 Router Build
      By CarveOne in forum CNC Wood Router Project Log
      Last Post: 05-15-2010, 07:08 PM
    3. when the cnc router is build, how do you make it work?
      By bassman74 in forum DIY CNC Router Table Machines
      Last Post: 08-17-2007, 11:54 PM
