| CNC Wood Router Project Log Post your CNC machine building log here only. |
#61
| I'd use Mach3, as the Mach2 settings aren't transferable to Mach3 if you upgrade (free), and Mach3 has a LOT more features. When you run the test, are you getting a flat line, or does it vary a lot? If it's not flat, then somethings probably interfering. If quicktime is installed, make sure qttask.exe (or qtask.exe ?) is not running. If that doesn't help, read through the optimisation list at www.machsupport.com for more things to try. Yes, it should be close to 24,600. Mine is 23,766, but it's very steady only varies by plus/minus 1 or 2
| Single line mode works well, Auto is not soo good?? | Darc | CamSoft Products | 16 | 10-26-2004 03:29 PM |
| Which came first, Solid Edge or Solid Works? | Arnie | General CAM Discussion | 3 | 09-15-2004 06:25 AM |
| sold works and 2d edming | wireguy | Solidworks | 4 | 05-22-2004 02:29 PM |
| Gibbs & Machine Works | cadman | GibbsCAM | 5 | 02-20-2004 10:15 AM |
| How does G 41, G42 works ? | BanglaTech | General CAM Discussion | 7 | 11-04-2003 11:38 AM |
