Ok it’s my turn now and all know the drill, long time reader first time poster blah blah blah.
My background is fitting and machining I have worked on various
CNC machines including center lathes, turret mills, machining centers, wire cutter and of course a router and I currently work as a contract draftsman.
5 years ago I decided to convert my lathe/mill to
CNC and did so on a very tight budget, this clouded my judgement and I made a poor motor selection. In order to break through the friction of the machines slides I had to run a reduction that saw the machine having a top speed of 200mm/minute. I found it extremely slow and frustrating and proceeded to shelve the idea.
So a few years passed by and I decided that I had a perfectly good driver setup and motors going to waist when really all I needed to do was use them on a machine with less friction and lighter cutting loads. I looked at a wire cutters and sink
edm’s but didn’t think they would be useful in most of what I do or would like to do.
That's when the router idea came up, I found
CNC Zone and started putting ideas together. I looked at simple designs for a first machine eg. jgro and made 3d models of my own concepts which led to more complicated designs that would require manufacture on a
CNC. I have been going round and round in circles and have completed several models but achieved nothing.
So I decided to get serious, make some firm decisions and finally make it happen. I put together a model that was easy to build at home with hand tools and my lathe/mill. I bought some materials and prepared to start my build. However my timing couldn’t be worse as I am in the middle of renovating my house (another long drawn out project but I won’t bore you with that one) and I have very little spare time on the weekends. Deciding nothing can stop me now I decided to build it on week nights. So this project will be a slow one I feel it will take 10-12 weeks of 1-2 hours 5 nights a week.
The machine:
Controller – Laptop running XP and Mach 3
Driver – Hobby
CNC 4 Axis board (Purchased 5 years ago so different to their current board which intend to upgrade to at a later date to increase my top speed)
Motors – 3 x Unipolar 127 once/inch NEMA 23
Router – Working area 800mm x 500mm x 85mm, Timber construction, Skate bearing slides, threaded rod lead screws.
The model is 99% complete I need to extend the table 50mm add a few fasteners and limit switches but everything else is complete. I have completed drawings for the z-axis and started machining some of the parts. I have attached pictures of the model (Later I will add an E-Drawing if anyone is interested) and photos of my driver setup. I endeavour to update my log weekly and include photos. I hope my log is interesting and helps others to embark on this truly enlightening hobby.
