Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 10-08-2008, 01:35 AM
ktb100's Avatar
ktb100 is on a distinguished road
5' x 10' NEW ROUTER BUILD
We are really excited about building this one !! The end result will have a 4' x 8' travel "X" and "Y". The Majestic AC Servo's running on single phase, 10 HP HSD 28,000 RPM spindle with an 8 station wine rack ATC and a Vacuum table. It will be controlled with Mach 3 using the Majestic all in one pc, Bob Campbell's combo board and Warp 9's Smooth Stepper. The bridge design is still on the drawing board. Deciding if height or rigidity is what is needed for this one. Naturally, this will decide how much "Z" travel it will have. The X & Y will run on rack and pinion, "Z" will be driven by a ball screw. All 3 axis will ride on Linear rails. Current calculations are showing insane rapid rates. The AC servos can run up to 3,000 RPM with 1 HP each. If I run it 1:1, with a 1.125 diametrical pitch, that equals 10,597 IPM. So, I think I will use a 5:1 and roll it about 2,000 IPM with all the torque needed for the cut too. I am optimistic that we can have this one done in a month. The 3 pic's posted now are from week 3.
I look forward to any suggestions and comments about the build.
THANKS !!
Kirk
ID:	67582   Click image for larger version
ID:	67583   Click image for larger version
Old 10-08-2008, 01:51 AM
wizardrule's Avatar
wizardrule is on a distinguished road
whoa!!! Monster unit!! be watching this one for sure.
Old 10-08-2008, 06:57 AM
CarveOne is on a distinguished road
I'm guessing that this one is not really for home garage use? Looks and sounds like an ambitious project. I'm watching.
Btw, good wine doesn't age well in an automatic tool changer. Just thought I would point that out.
CarveOne
"A $1,000 electronic device will almost always protect a ten cent fuse."
Old 10-08-2008, 01:25 PM
TOTALLYRC is on a distinguished road
Thumbs up
With all the strength and rigidity that you have already built in I don't think I would sacrifice it for a little more z heightThat being said, with the way you are building, I bet you could have a 12" Z without giving up any strength.
Green with envy
Mike
Old 11-07-2008, 09:47 AM
ktb100's Avatar
Just a quick update. I put the power to it today and looks good. Using my laptop and getting it to bounce around was sweet ! Spindle sounds ok.... I am using a "new to me" VFD and cant seem to get the decel / accel right or I am missing something.. It squeals when it takes off and stops. I have installed a good sized regen resister so stopping for the ATC shouldnt be a problem.. If I change the timing, it coasts.... My lack of experience with this VFD is 100% of the problem .... It will be solved shortly. I did however change to a 15HP 24,000 RPM spindle. The 10 just looked too small. I have added a pic of the electrical cabinet and control console. I have put wheels on the console but am not 100% sure I like it. It rolls around just fine. Should I be able to roll it around or have it stationary and use a remote MPG with start / stop and e-stop? I would sincerely like to hear what anyone else thinks.
Kirk
ID:	69202   Click image for larger version
Name:	5' x 10' 15HP Router.JPG‎
ID:	69203   Click image for larger version
Old 11-07-2008, 09:58 AM
Question WILL IT FIT ON MY DINING ROOM TABLE
I AM GREENER WITH ENVY NOW THAN AT THE START OF THIS PROJECT
Old 11-07-2008, 11:12 AM
ger21's Avatar
How about 100 more pics?
Old 11-07-2008, 12:38 PM
That's an interesting gantry riser design. Looks really sturdy. I like it just for its "elegant looks". Another 100 pics requested in addition to ger21's request for 100 pics.
CarveOne
Old 11-07-2008, 01:44 PM
Med-Pac is on a distinguished road
Very impressive. I agree with the last 2 ger and carve one. We need more pics. By the way, what is your vac table made out of?
Mike
Old 11-07-2008, 05:02 PM
Originally Posted by ktb100 View Post
(snip)
Kirk
As long as the console stand isn't top heavy enough to fall over unintentionally, or tries to roll away from you while using it, it should be fine as it is. The shape of the console stand clearly shows an artistic fabrication talent.
Questions:
1. Is the stand made of steel, or aluminum?
2. Is this machine for in-house use, to be produced for sale, or a one-off build for a customer.
3. Will the plans be available here after I win the state lottery?
Really nice work being done there.....
CarveOne
  #11   Ban this user!
Old 11-08-2008, 09:33 AM
ktb100's Avatar
Hello all and thanks for the replies !
I will get more pics too.
To answer Med-Pac, The Vacuum table has not been installed yet. I am putting 1" PVC on it and will machine it where it lays.
CarveOne,
1. The stand is made of sheet metal steel.
2. It is being produced with the intent to sell.
3. Can't win if you don't play ! I don't think I will be giving those away any time soon. Never know though......
Kirk
  #12   Ban this user!
Old 11-08-2008, 10:31 AM
Is that the vacuum pump lurking in the background of the control cab picture?
It looks like it matches everything else in beefiness.
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-08-2011 12:16 AM
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 08:51 AM
Newbie- Build CNC Router? jeffmorris DIY-CNC Router Table Machines 75 04-22-2008 03:52 PM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 11:33 AM
