Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #37   Ban this user!
Old 01-12-2009, 12:55 AM
ktb100's Avatar
ktb100 is on a distinguished road
Originally Posted by eloid View Post
any updates or pic pls....
Here are a few quick pics of the x rack and head covers. I had to go back to the original pinion. I broke the split one and am waiting on a new one. In order to make an omelet, you must first crack a few eggs.
Name:	x rack.JPG‎
ID:	73439   Click image for larger version
Name:	head covers.JPG‎
  #38   Ban this user!
Old 01-14-2009, 05:15 PM
eloid is on a distinguished road
thanks for the pics
your machine looks abit like a thermawood...
do you use and spring tension on you x axis pinions, i see a set screw adjust ment....
what about your long dual y axis are the connected in any way? or just slaved?
any more pics would be great!...love the size ,quality of work....great job on it....also any info on you gear ratio for x, y
  #39   Ban this user!
Old 01-14-2009, 06:13 PM
ktb100's Avatar
thanks for the pics
Hi Eloid,
Thank you for your kind words.
This is a 100% original design. Not a copy of anything.
The tension is done by the screws pulling the belt tight, no springs at all. The dual drives are slaved in the software. They each have their respective amplifier and are assigned as separate axis. This one has 2:1 ratio on the pulleys and I put 10:1 ratio gear boxes on it thus, 20:1. The next machine will not have a pulley configuration at all. I will simply put a 20:1 gearbox and mount direct to the pinion.
Regards,
Kirk
  #40   Ban this user!
Old 01-15-2009, 08:23 PM
few question...
why a 20:1 pulley set up can you explain....
is seen most 5x10 machines 10:1 or 8:1
I can understand yours is heavier machine?
im guess you have very fast high torque motors
and want more resolution?
  #41   Ban this user!
Old 01-16-2009, 10:35 AM
ktb100's Avatar
few question...
I was running a 3,000 RPM motor at 150 RPM. The resolution and performance will be better as I run the motor closer to the designed RPM.
Regards,
Kirk
  #42   Ban this user!
Old 02-23-2009, 10:53 AM
pero81 is on a distinguished road
any updates on your's cnc?
  #43   Ban this user!
Old 02-23-2009, 11:02 AM
morvenmachine's Avatar
morvenmachine is on a distinguished road
impressive
  #44   Ban this user!
Old 02-23-2009, 11:41 AM
ktb100's Avatar
Smile Quick update
We moved the machine to the showroom floor. We still have a few things to finish up with but over all I think it turned out well.
Let me know what you think.
Kirk
ID:	76268   Click image for larger version
ID:	76269   Click image for larger version
  #45   Ban this user!
Old 02-23-2009, 11:57 AM
Good job. It looks awsome. Is Z servo driven directly to the ballscreew or by pulley sistem?
  #46   Ban this user!
Old 02-23-2009, 12:07 PM
ktb100's Avatar
Z is a direct drive to the ball screw.
  #47   Ban this user!
Old 02-23-2009, 01:42 PM
asuratman is on a distinguished road
Hello ktb100,
What is the servo motor driver? I did not find you mention about this. Is that AC servo kit belong to you or it is after market kits? Asuratman.
  #48   Ban this user!
Old 02-23-2009, 02:22 PM
ktb100's Avatar
Originally Posted by asuratman View Post
Hello ktb100,
The servos are made by our factory in Taiwan. I have a list with specs on our web page. www.majesticmachinery.com just look under the automation link.
THANKS !!
Kirk
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Newbie- Build CNC Router? jeffmorris DIY-CNC Router Table Machines 75 04-22-2008 02:52 PM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
