Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 08-06-2008, 08:49 PM
lamicron is on a distinguished road
4´x 8´router build
Hi all, I ´ve alr¡eady build two CNC 4´8 plasma tables, now building same size router, the question is: i was going to use rack and pinion (20 pitch, 20 tooth due to the length, Is it better to use ball screws for this length , which diameter will be the best? If it is best rack ansd pinion wichich pitch.
I´ve seen a biesse router from italy (big one!!!) with gear rack module 2.5
Anyone have build something like this?
Thanks for help
Luis
Old 08-06-2008, 11:48 PM
harryn is on a distinguished road
Are you happy with the result of your plasma table - for accuracy, speed, durability, etc ? If so, then maybe the easiest way is to just improve on your current projects.
Old 08-08-2008, 01:21 PM
contactirfu is on a distinguished road
look at www.mechmate.com, they use all rack and pinion and have specified the exact sizes.
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-08-2011 12:16 AM
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 08:51 AM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 11:33 AM
1st cnc router build ajl6549 DIY-CNC Router Table Machines 1 11-02-2006 12:47 PM
