Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #49   Ban this user!
Old 01-21-2005, 11:26 AM
stevec is on a distinguished road
Gerry,
Thanks for the tip.
I have some thin CA glue that I used for plane building. I will try it!
Steve
  #50   Ban this user!
Old 01-22-2005, 04:08 PM
sp00k1e's Avatar
sp00k1e is on a distinguished road
adjusting the rails
Darren or anyone, do you have any helpful hints about methods of adjusting the rails on the machine, or is it just trial and error. Whatever I do it seems like the rails are bent (there not, i've checked them on a flat table). If I get them tight at either end somewhere along the travel one or other bearing isn't rolling along with up to a 5mm gap from the rail, maybe the bearing holders are not parallel, but with the tools i've got this is going to be difficult to check. I havn't got the leadscrews mounted yet, just trying to get everything lined up, and I want to cut something
Thanks Paul
  #51   Ban this user!
Old 01-22-2005, 04:31 PM
carlnpa is on a distinguished road
I had the same type problem, 7 of 8 rollers would be in contact. Tighten one end, roll to other end and tighten, always 7 of 8. My bearings were dead on per the JGRO thread. I finally just made a slot in the oddball off roller and adjusted it individually. I thick the structure itself torques up when the linear bearing is attached.
  #52   Ban this user!
Old 02-17-2005, 04:13 PM
Darren,
I need advise on the chopper board settings from Hobbycnc that are running on my version of the jgro plan. I removed all the jumpers off the board so I guess I am in 1/2 step mode. Can you run these boards at full step and if so how? What mode and jumpers do you have setup? I am turning a 1/4x20 lead screw with the 80oz motors.
Thanks,
Steve
  #53   Ban this user!
Old 02-17-2005, 04:36 PM
WP1 WP1 is offline
WP1 is on a distinguished road
I believe the recomendation of Dave Rigotti of HobbyCNC is to start with the 1/4 step mode and only deviate from that if you have problems such as vibration or the controller can't produce steps fast enough. Also the only options are 1/2, 1/4, 1/8 and 1/16 microstepping, there is no full step option.
You should probably join and review the posts on the Yahoo groups HobbyCNC forum which is the official HobbyCNC support forum (link to it from the HobbyCNC page).
  #54   Ban this user!
Old 10-28-2005, 04:54 PM
mrbaseball is on a distinguished road
Power Supply
Originally Posted by CNC Darren
hi Krashlnd,
The chopper drive is from hobby cnc as a complete 3 axis driver and chopper on one board, I like it so far and no problems with it. The Machine I built is from Jgro's plans you can find in the downloads section here on the cnczone, great plans and very detailed! My maching has a few things changed on it but for the most part it is built to the plans. No price on the supplys yet, I want to do some more testing with it befor I sell any to make sure that they will work with no problems. They are used and pulled from working equipment but I would check them before any would ship. Specs so far are 15 amp on the 38v line and 15 amp on the 24v. I will be including a heavy duty cord with 15 amp plug, switch harnes and a 24V 80mm fan with them.
Darren,
I rec'd the power supply today, but no switch harness or fan. Did you discontinue the additona of these?? also do you have a diagram that tells where everything hooks up? i.e.- AC input, DC output??
Thanks,
Gene
  #55   Ban this user!
Old 12-09-2005, 08:36 AM
JTKELLEY is on a distinguished road
Hey there Darren and to all that might question the tapping of wood. As an R/C hobbiest, I have had to tap wing hold downs may times. If by chance you don't feel warm and fuzzy about the strength of wooden threads, try the following. Tap the hole first, then use "thin" Cyanoacrylate glue in the hole, then run the tap thru the hole again. The thin CA will have a "wicking" action and harden a penetrated depth of about 0.0625"-0.125". If you aren't careful though, you could very well glue the piece to your table top or even worse,,,,, your hands. In such a case, the use of acetone will be in order. Otherwise you can do your tapping procedure after you paint and finish the MDF, which allows for the use of vasaline to prohibit the spread of the glue to the outer surface of the part. This vasaline should of course be place on any surface that you do not want the glue to affect. I hope this helps!!
Jason
  #56   Ban this user!
Old 06-04-2007, 01:28 PM
latif is on a distinguished road
pls email us the master plan digram we need to build
thank you
klg100@yahoo.com
  #57   Ban this user!
Old 06-04-2007, 02:12 PM
where can i get the digram catalouge for wood table cnc
klg100@yahoo.com
Old 06-04-2007, 04:53 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
You are aware that the last post prior to yours was december of 2005?
And Darrens last post was Jan. of 2005?
So you may not get a responce to your questions.
joe
Old 06-04-2007, 05:39 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
If you are looking for plans for the JGRO router you can find them here
http://www.cnczone.com/modules.php?n...warticle&id=24
Mark
Check Out My Build-Log(s):
http://cnczone.com/forums/showthread.php?t=4716
CNC Router Version 1 [====================] 100%
http://cnczone.com/forums/showthread.php?t=39294
CNC Router Version 2 [=|-----------------------] 5%
  #60   Ban this user!
Old 04-02-2008, 12:44 PM
Khalid's Avatar
Khalid is on a distinguished road
hello daren...where r u? n what bout ur 4 x 4 machine?
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 10:46 AM
mvaughn's CNC machine worklog mvaughn CNC Wood Router Project Log 155 01-07-2008 03:05 AM
CNC Darrens Work Log V2 CNC Darren CNC Wood Router Project Log 19 05-27-2007 04:03 PM
CNCRob's CNC Worklog CNCRob CNC Wood Router Project Log 2 02-26-2005 01:21 PM
