thats a nice cut, kindly post pictures of the full machine.
Awesome machine! The motion looks super smooth and fast. If you want to get your Z-axis closer to the gantry to cut down on flex, I now sell a Z-plate that will bolt directly to the carriages spanning your Z-rail. You just need to tap the carriage holes to 3/8-16.
If you're willing to provide a Bill of Materials for your machine, I'm happy to send you a Z plate and low profile bearing (that the Z plate can slide over) for free. I'd like to post the BOM on my site since there's lots of folks asking for good machine plans, and yours is one of the best I've seen. Shoot me an email through the website if you're interested.
Best regards,
Ahren
www.cncrouterparts.com
Very Nice! Looks like everything is going quick and smooth.
Now comes the sleepless nights, cutting everything you can think of
I'll have to stop over and see it "live" in action!
Good work again.
Everything that everyone wants you to make, is always 1 inch larger than what your machine can cut.
Camera broke so I took some video of my machine.
Overview
X-axis
Y-axis
Z-axis and drive screw
Electronics
Kiteboard
Drilling out the holes for the tnuts that are used for the foot straps.
Cutting out the board
Finished boards
Looks like it is working pretty good, I am about to convert my system from xylotex to G251's, a 48 volts 7.5 amp, Keling Steppers and a C10 break out board so it was good to actually see one working
Good Stuff....
Cheers, Bob
http://www.ocm.com.au/wordpress/
Sieg,
Did you get the Z-axis plate and bearing I sent yet? I'm interested to see if it works out for you.
Thanks,
Ahren
Yes I just got it yesterday. I started to put it on... but I have been getting busy with other things. I'll take some pictures when I get it together.
Very nice machine. When mine grows up he wants to be just like yours lol. Is that the Milwaukee router your using, very quiet . what cutting and rapid speed to you get with the 5 start?I just ordered 8tpi 4start and cant wait to hook them up. Graham
I've been cutting at around 100ipm... I'm pretty sure I have played around with it at 200-300ipm not cutting. I've only cut a few things on it so I haven't pushed it to its limits.
I'll try and post a few pictures the next few days of what I have cut.
The router I am using is a Haitchi m12vc router. Great price for a refurb one here...
http://www.reconditionedsales.com/Hi...d)___i310.aspx
Wow thanks for the link, $60.00 man thats a great deal and even a yr warr. Thank you so much,cant wait to see more picts.Graham
Hey sieg
Couple questions for ya...
Did you go with a 3'x5' b/c you bought a 36" and a 72" lead screw so you could cut it for the Z & Y? The reason I ask is b/c that’s exactly what I'm contemplating, lol... how did you compensate for the deflection on the Y? I was going to use a piece of 3030 for the length, but according to the deflection calc ahren said to play with it comes to 0.015in over a 60" span. The 3060 only has a 0.002in over the same span, which is great b/c with the 1/4 in steel its probably nill, but they are awful proud of the 3060 & 1545 in at least a 5' sticks... I've even debated the idea of filling the center cavity of the 3030 with something, maybe extremely thinned cement and vibrate it in, then let it set for a week (like I could leave it alone that long) or a vertical peice of 1" flat steel if it fits tight enough?? I like the concrete idea better though
It looks great btw.. lets get them pictures, I would really like some more of the base…
