Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #13   Ban this user!
Old 05-13-2008, 07:40 AM
wfung is on a distinguished road
The setup is essentially just 2x 5V lines, and a parallel cable. I've disconnected the drives, as I'm sure they are not the problem.
The 2 x 5V lines are *both* coming from the computer's USB ports via 2 USB cables. I know this negates the electrical isolation of the system due to the common ground, but I'm not expecting anything nasty coming through and destroying my PC (the drivers are optically isolated as well anyway). With regards to the amperage, one USB port should be able to draw around 700mA, and seeing as I'm only utilising 2 outputs, with no loads on them, it there should be sufficient current available.
The problem is coming from the parallel port - I oscilloscoped the outputs today. Disabling all axis instead for X, and setting pins 6 and 7 for step and direction, and I checked out the waveforms as I jogged the system.
The voltage is either at zero, or perpetually at 5V. Changing the direction did *not* change the logic state on the direction pin, and I could discern no noticable pulse waveform on the step pin with the oscilloscope.
I suspect that this is a software problem of some sort, because I've tried this on two computers, with no avail. I've run the drivertest that comes with Mach3, and both computers have passed.
Tried it on a vista computer as well (after applying a registry fix) with no luck either....
Does anyone have any clues? Its really begining to frustate me, as I anticipated that the electronics would be the easiest part of the build.
Thanks,
-Wilson-
Old 05-13-2008, 08:07 AM
ger21's Avatar
If changing direction did NOT change the voltage, how was it at both 0V and 5V?
Try changing the port settings in the BIOS. Try all the different settings.
Also, check the port address in the device manager. The setup video on the Machsupport site shows how to get the correct address.
  #15   Ban this user!
Old 05-13-2008, 08:36 AM
Hi Gerry,
Thanks for your help.
I should've been a bit more clear. The direction pin was stuck at 5V, whilst the drive was at 0V (might've been the other way around), but the important thing was that they remained unchanged regardless of whether I was jogging, or jogging in a different direction.
The parallel port is on 0x378, which I've already checked. The LPT port is currently on ECP mode. I shall try it out with SPP tomrrow and see if that gives any difference.
If all else fails, I'm waiting for a PCI-parallel card from ebay to sort out my woes.
-Wilson-
Old 05-13-2008, 10:15 AM
ger21's Avatar
Set the port in mach3 to 0378, not 0x378.
  #17   Ban this user!
Old 05-14-2008, 05:38 AM
blackbeard52 is on a distinguished road
Have you tried contacting Aurturo at cnc4pc? he is usually very helpful in troubleshooting his products? www.cnc4pc.com
  #18   Ban this user!
Old 06-23-2008, 11:31 PM
Talking X Axis
Haven't been able to do much with this project due to uni, but I've managed to acquire a nice piece of aluminium plate. It measures 865x165x40. Weighs 16kg!
The nice thing about it is that it was cut from a very large plate, and isn't extruded material. The surface is much flatter, and seems ground.
I've attached a picture of a mock X axis assembly, which has 2 NSK LH25 linear rails, and a THK 5mm pitch ballscrew. The whole lot will be enclosed with bellows to protect against dust.
This assembly will be bolted onto the gantry, and will be about 500mm from the table surface. Previously I was worried about the gantry crossplate flexing under load... not any more. If I put my whole weight on the plate, calculations predict that it will flex 35 microns
I've also done some calculations for the gantry uprights. I intend to make two square columns from 80x20 aluminium bar. Milled and bolted together. I had considered using 8080 extrusion, but the moment of inertia with the plate column is around 3 times higher than the extrusion, and at roughly the same cost / meter!
After doing some calculations (ignoring any inertial effects - assuming slow cutting), a 500N load on one of the uprights produces 0.02mm of deflection.
What are the prerequistes of being able to machine steel? Would an aluminium machine, sufficiently rigid be ok? Or would there still be some nasty chatter / resonance effects given the light weight of aluminium?
It seems like I might be able to machine steel plate given a reasonable spindle? (Not that I intend to).
Has anyone seen an adjustable gantry in a DIY design? ie, being able to lower / raise the gantry bridge depending on the cutting application. I've searched the forums without too much avail. It seems on these hobby machines, having an adjustable gantry would really increase the versatility of them. Being able to lower the gantry to increase rigidity whilst machining flat materials, whilst still being capable of doing 3D contouring by raising the gantry bridge to achieve the required height clearance.
I have a few ideas regarding this -
i) Using a round column and using adjustable clamps (think of a drill press)
Perhaps with 2 round columns / side to increase rigidity
ii) Using a square column and regularly spaced bolt holes
iii) Make 2 dovetail columns
Adjusting the height can be as simple as adding a vertical allthread/acme screw to raise/lower the gantry. Only disadvantage would be having to dial in the gantry everytime, unless you could add some accurate dowel pins.
I'm considering option 2 at the moment, adding a 16mm linear shaft + 16mm leadscrew on each side to support and raise the column.
Ideally, I would like to try the dovetail method, but I'm afraid there will be some racking problems over the lengths involed (~800mm) Dovetail cutters are also very expensive
What do you guys think?
-Wilson-
ID:	62000   Click image for larger version
  #19   Ban this user!
Old 06-24-2008, 01:38 PM
java77man is on a distinguished road
Yeah for Adjustable Gantry!!!
-Wilson-
I am presently building an adjustable bridge into my DIY mill design. You are right
it is a very nice feature of a cnc design, unlike the useless tilting vertical column found on X2 mini-mills, which I own. I have two back to back INA 20mm
rails going vertical at left/right handsides on my design, with the stage
areas linked together to get the rigidity that I feel is needed to support a heavy stainless steel x-axis; my y-axis is moveable at the base of design.
I will be watching your build log closely.
Thanks for sharing.
Jesse
(Java77man)
  #20   Ban this user!
Old 06-28-2008, 05:04 AM
Homemade Belows
This machine will have swarf protection on all axis. The A and B axis are fully enclosed, and the X,Z axis will receive bellows to protect against swarf. (Haven't decided how to protect the Y axis yet)
I've posted up a picture of a set of homemade bellows. It is folded from a section of canvas like material. The material is used for roll up blinds (The type where you tug the string, and if you're not careful, the blind rolls up all the way to the top). The material is fairly springy, but it seems to hold its shape very well. I intend to paint it and coat it with some varnish.
Seems like a good cheap DIY way for swarf protection when coolant isn't being used. I hope material stands up to the constant creasing.
If anyone is interested, I'll post up the geometry needed to make a generic bellow of a certain height / width, but it should be fairly easy to figure out.
Does anyone have any thoughts regarding the adjustable bridge idea?
-Wilson-
  #21   Ban this user!
Old 06-28-2008, 09:52 AM
Adjustable Gantry idea: implementation?
Wilson:
Okay, you asked for it; thoughts about implementation. I like your 3 possible
methods, actually I considered all 3. (i)The Round column was a favorite in my thinking as I thought I might use two cheap $50 drill presses to obtain the
components necessary to make a slipping round column of sufficient strength
to both support and also to lock the gantry bridge at a specific height. It even had two headunits to use as a good right angle for use at the top of the bridge. I was thinking 500mm bridge to span however.
(ii) square column with spaced bolt holes, also simplified the height adjustment by having unique step height settings. If enough cheap steel
was available and a counter weight to make locking the set levels easy, it
could also work.
(ii) two dovetail columns, boy that would be nice, to just rack/pinion them in
place or dial adjust them with a heavy weight screw, something like the screw in a mill vise.
I had difficulty making a choice among the 3 methods: it wasn't until I got a
eBay purchase that forced a decision: my choice was dual square column using linear rails/bearings on each left/right hand side. A counter weight will be absolutely necessary. A heavy screw will be the next addition to each
side for easy height adjustment, and finally perhaps a rod/gears to drive both
screws at the same time.
My thinking was rigidity, rigidity, rigidity as much as possible to make any of the 3 choices work. When steel doubled in price, I started looking for complete assemblies to buy on eBay rather than raw materials to build with
because it was actually cheaper to buy than build each axis.
It is tough to make a choice, I am just glad that I now am bumped into action
on what to do, and can now start to work on the implementation.
Best of everything in your choice,
Jesse
(java77man)
  #22   Ban this user!
Old 07-09-2008, 10:21 AM
Preliminary CAD Design
I've posted a preliminary CAD design drawing here to spark some discussion.
All 3 linear axis are positioned at machine zero in the drawing. The drawing still has several errors - the columns and table both need to be lengthened, and the X axis drive components are still missing, but the main look of the machine is there.
I've purchased a slab of 570x640x40mm aluminium for a good price to use for the table. Whilst I'm at it, I will be adding provisions for flood coolant.
How do people usually design the base on large CNC routers?
When I look at my CAD drawing, the base seems very flimsy compared to the rest of the structure. It is composed of 100x25 aluminium plate, with 50x50 3mm thick square tubing in the middle. The base will be bolted to the bench.
I've seen that the designs from tormach and Haas tend to have a welded steel subframe...however, this is something I would like to avoid, due to the inaccuracy of welding, and the need to remachine / epoxy the mounting surfaces for accuracy
Unlike many other CNC routers, my design has a very high centre of gravity, which is worrying.
In response to this, large industrial 5 axis routers tend to have a fixed gantry and moving table...which isn't practical for me given the space constraints of my garage.
I've considered building a router similiar to Rainnea, but that would necessitate 2 leadscrews and parallel drive...something which I don't have. It would also have much less versatility when it comes to switcing between milling aluminium and 5 axis plastic routing because the linear bearings will be permanently suspended quite high above the work surface.
I've settled on having regularly spaced tapped holes up the column onto which the Y axis can be bolted at various positions. The Y+Z axis weight will be mostly offset by two 250N gas struts working in tandem.
It would be awesome if some builders here could shed some light how to construct a solid router base or just some general advice
I shall hopefully start work on the Y axis this weekend. I've made a lot of effort to design it to be as modular as possible. (Much like a "bolt-on" linear actuators). Should be interesting trying to machine a 865mm plate on a machine with only 600mm travel.
-Wilson-
Name:	prelim router.PNG‎
  #23   Ban this user!
Old 07-18-2008, 08:54 AM
Y Axis
Just a quick update, the Y axis is almost finished. The 40mm aluminium plate has been machined with 5mm deep channels to accurately locate the linear rails (as recommended by NSK). Additionally, there are some large 12mm holes for mounting, and were also used to clamp the piece on the mill table. M6 holes were tapped in the ends to fix on the end plates + act as mounting points for cable carrier, gas struts, etc.
Just need to finish the end plates, the carriage plate and to fold the bellows. The axis now stands at 22kg and is 800mm long.
Disappointing, I found out there was a bow in the piece i was using. It was bent around 1.5mm in the middle...I clamped that area as lightly as possible as not to cause excessive deformation, but I feel that the axis won't be as accurate as I had hoped. Probably will add shims under the rails in the future as needed. Had to machine the plate in 2 passes, because my mill only has 570mm travel.
I think if I ever build a second machine, contrary to most builders here, I will build a *smaller* machine than the first!
[Tip to new builders - start with a tabletop version and work your way up!]
Comments / suggestions would be greatly appreciated
-Wilson-
ID:	63279   Click image for larger version
  #24   Ban this user!
Old 07-18-2008, 11:15 AM
Clockwork is on a distinguished road
Don't know if you saw my post containing a pdf of a US Patent of a 5 Axis Router.
The thread is here:
A 5 Axis Router
3 projects of CNC Router 3Axis, 4 Axis and 5 Axis LuthierX General Metal Working Machines 11 07-06-2008 08:26 PM
A 5 Axis Router Clockwork Open Source CNC Machine Designs 11 06-02-2008 03:10 PM
3 projects of CNC Router 3Axis, 4 Axis and 5 Axis LuthierX General Metal Working Machines 0 02-25-2008 09:12 AM
4th axis on my router ronnieman CNC Wood Router Project Log 10 03-18-2007 06:35 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
