| CNC Wood Router Project Log Post your CNC machine building log here only. |
#49
__________________ Everything that everyone wants you to make, is always 1 inch larger than what your machine can cut. |
#50
Well, everything is pretty much done with the machine now. I got the top cutting surface and t-slot rails for clamp downs mounted to the upper table frame. The upper frame is made out of steel tubing and the top surface is a white melamine(sp?) coated 3/4" mdf with 1/2" aluminum dual t-slots in between. All that is left is squaring and leveling the table. Right now it's off by about .025" to .030" in a couple corners so some shimming is in order but not a big deal. Then it can be fastened to the lower frame in a somewhat permanent manner, then the cutting can begin!!!!!! Here's a new video of it actually making something on the 4th of July http://www.youtube.com/watch?v=Wn-9DeWCQW4&feature=user Hopefully I can have some updates very soon on how the belt-drive system works as far as actual cutting force, deflection, rebound and all that nitty gritty stuff that I'm most interested in. So stay tuned
#51
| Hi Stepinator, There seems to be some sort of jerks which I am also facing on my machine, maybe due to other processes running in background on windows?, Even Iam having that problems, see my machine video for just the x-axis - http://www.cnczone.com/forums/showth...=46998&page=10 BTW what is the configuration of the computer running Mach. RGDS Irfan |
#52
The jerking is mostly because of changing feed speeds on seperate lines of code (and the acceleration rate). Running the machine in a straight line at a continuous feed rate should not be jerking. My PC is an old one, AMD 900MHz Duron, 512M ram, no additional software installed other than XP Home.
#57
| Stepinator, Could you elaborate on your drive system, mainly tooth count on the steppers (small and large cogs)... 3:1 perhaps? (20 tooth to 60 tooth XL and 20 tooth on the L Cog) And what is the source for the red urethane idlers? Regards...Rick Last edited by rrdiaz30; 07-30-2008 at 12:07 PM. |
#58
| I use 6:1 gear ratios. Urethane rollers from McMaster Carr.
#60
| It really is working nicely. I'm very impressed so far with the performance both speed and accuracy. The table still needs a little leveling but that won't be a problem. At this point I don't think I'll change anything on the machine, I'm just really satisfied with how it turned out. That doesn't mean I won't add other goodies to it over time, in fact I'm already designing a touch-probe and a 4th axis for it.
| Tags |
| 80/20, belt, belt-drive, pulley |
| Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? | pfeist | General Metal Working Machines | 11 | 02-13-2012 02:12 AM |
| Timing Belt Design | dougub | Linear and Rotary Motion | 5 | 07-28-2008 09:19 PM |
| Need Sherline Belt & qestion on X2 Belt Drive? | Oldboy | Benchtop Machines | 12 | 03-06-2008 12:42 AM |
| Belt-drive design | cnczoner | General Metal Working Machines | 7 | 05-28-2004 12:48 AM |
| Scratch Design Questions | danowar | DIY-CNC Router Table Machines | 7 | 12-30-2003 04:16 PM |
