Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #13   Ban this user!
Old 05-04-2008, 11:52 PM
dmoore is on a distinguished road
Finishing up the support structure...
For the legs I elected to use 2" x 2" x .120" wall tubing since I feel it looks a little more finished and I didn't mind purchasing another type of steel. More importantly, it allows me to use these nifty little nylon inserts from McMaster-Carr (60945K31) and these really nice self leveling feet (6111K373) also from McMaster-Carr.
For the bracing, I am using 2" OD x .083" wall tubing. For the tube on tube action I am fish mouthing the joints using paper templates.
To crush the ends where the tube meets the beam and legs, I used my shop vice. Does anyone have suggestions on a better way to form the crushed/oval ends?
Even though the cross bearers are bolted, I will be welding the side supports back on after I paint it. The tinking is - if I need to disassemble it in the future, I can just cut off the side supports, move it and then re-weld it upon reassembly. The main beams with the legs and supports is liftable my one person, so with the boltable cross bearers, it makes the MechMate "somewhat" portable.
ID:	59048   Click image for larger version
ID:	59049   Click image for larger version
ID:	59050   Click image for larger version
ID:	59052   Click image for larger version
  #14   Ban this user!
Old 05-04-2008, 11:58 PM
Moving the monster!
I finished the legs and support structure, so now it's time to flip it over and reassemble it. I propped up one main beam with my workbench and then with the two end cross bearers attached to the other beam, I lifted it upright and then attached it to the other beam. Once both were attached, I "walked" it crab-style into position where I squared it up and then attached all the remaining cross bearers. All done it was within 1/4" square.
ID:	59054   Click image for larger version
  #15   Ban this user!
Old 05-05-2008, 12:03 AM
Y Car Welding
Other than some confusion about the pictures for the weld-up being for the orginal MechMate and which side the the counter sunk holes go on, it all snapped together perfectly. Here here Gerald!
I know that Gerald says that clamps aren't neccessary but rather than risk it and to close a few small gaps, I put a few clamps on it.
When it was all said and done, it turned out completely true and straight.
ID:	59056   Click image for larger version
ID:	59057   Click image for larger version
ID:	59058   Click image for larger version
ID:	59060   Click image for larger version
  #16   Ban this user!
Old 06-08-2008, 03:50 PM
Update....
I'm sorry I didn't finish my posts but I have completed my MechMate. In the process, I have posted a very detailed BOM for the MechMate here:
http://www.mechmate.com/forums/showthread.php?t=814
Link to the current MechMate BOM in Microsoft Excel (2003 format):
http://www.dmoore.com/MechMate/bom.xls
Link to the current MechMate BOM in HTML format:
http://www.dmoore.com/MechMate/bom.mht
  #17   Ban this user!
Old 06-09-2008, 12:51 AM
lumberjack_jeff is on a distinguished road
That BOM is awesome
You've done a huge amount of work documenting the requirements. Thanks and well done!
When I'm ready to build, I need to look carefully at your solution.
  #18   Ban this user!
Old 06-09-2008, 09:13 AM
harryn is on a distinguished road
Hi, Thanks for posting this - nice work.. Did you happen to post any final pictures of the unit or video anywhere ?
  #19   Ban this user!
Old 06-09-2008, 01:34 PM
I don't have any photos of the completed, painted MechMate posted yet but I do have video of it prior. They are posted here:
Introducing the "full-size" MechMate router
Tags
4x8, cnc, mechmate, nuts, squirrel
Introducing the "full-size" MechMate router Gerald_D DIY-CNC Router Table Machines 68 08-24-2011 06:17 AM
My "S.H.I.G." router build starts picbits CNC Wood Router Project Log 21 05-12-2008 12:48 PM
First Router Build, Is The Frame "Beefy Enough" jimbooboo DIY-CNC Router Table Machines 2 04-06-2008 12:49 PM
G320 "common" or "+5vdc" why do they vary? beezerlm Gecko Drives 3 01-12-2008 04:00 PM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 10:54 PM
