| CNC Wood Router Project Log Post your CNC machine building log here only. |
Got the electronics, bearings, and rails... going to begin construction soon. 55 inch 20mm pillow block rails. (Same length as foos) 15 inch THK rails for the Z. 34 inch Thompson 1" for the Y. (Same width as foos) ![]() Gecko 203Vs CNC4PC 11G 400 VAC 50VDC 8Amp PSU KL23H276-30-8B Stepper Motors... http://www.kelinginc.net/KL23H286-20-08B.pdf Got the electronics working... so figured it is time to start. Planning to keep the Foos theme (Foos guys for dampers and table painted as soccer field) The foos table has a weak tabletop. Going to replace with a buildup top. Sides of the foostable must be cut to allow for the gantry slide. Any thoughts? |
| Wondering if these would benefit anyone. I pulled the foosguy rods out of the table. There are 8 ranging from 3 feet to 4 feet. Upon further examination... they are 5/8th inch drilled at various spacing and tapped at one end. http://www.foosballstore.com/product...iption/976.cfm Thompson sports makes the ones on the website... think that is the same Thompson that makes the linear rod? When I was first starting out my cnc design I was looking for rod... if it were a snake... Should I sell them on ebay? |
After much soldering, the control box is near complete. Still need to make back panel and lid. Tested all connections and verified all motor operation. Everything is working great. Used Serial ATA cables (SATA) for control wires between the breakout board C11G and the drivers 203V. Was worried they would melt, but they are working great. Apparently the signal amps are extremely low. Noticed an occasional bump in the motors as they are turning around 70,000 steps per minute. approximately one bump per second. They seem to be running well, but there is a bump noise consistently... is this normal? From sound to text .... weeeeeeeeeeeeeeeeeeeeee thump weeeeeeeeeeeeeeeeeeeeeee thump weeeeeeeeeeeeeeeeee thump. The motors seem to be moving at a consistent speed throughout so I am not too concerned, but wonder what causes this. Here are some pictures of the control box... |
Now that the electronics are 95% complete (still need to attach the limit home switches), I have started on the mechanical portion. I bought a solid core door to place over the foos. I'm going to attach mdf and t-slot tracks to the door. I'm going to put the Y (or X? ... the long ones) directly attached to the door. I got these 20 mm Linear rails which are 55 inches long. Is it okay to mount these sideways? Or does the flat of the support need to be facing downward? I tried them in both configurations and they seem to work the same. So I am currently planning to connect them to the edges of the door. I have used a solid core door in the past for a workbench. The humidity in the northwest has extreme fluctuations and have had no problems with it. Has anybody used a solid core door in the past? (basically veneered MDF) |
#11
LOL... I'll let the results speak for themselves... I'm currently considering Elmers or Duct tape for the piece I'm working on now. Actually... I'm leaning toward less of the foos table and more of the door. I think the Foos will be something I just set this cnc on top of. The Foos field isn't as sturdy as I had thought. Completely worthless as a work surface. Maybe I can keep the functionality of the foos with a removable CNC top. |
| Another Newbie begins! | HomeMadeCnc | DIY-CNC Router Table Machines | 40 | 02-04-2009 08:56 AM |
| The Journey Begins | nc cooter | Benchtop Machines | 3 | 03-29-2008 06:50 PM |
| So the build begins..... | Gallop | CNC Wood Router Project Log | 3 | 06-24-2007 05:58 PM |
| And so it begins | Graham S | CNC Wood Router Project Log | 29 | 06-15-2006 08:40 AM |
| The Journey Begins.... | mtuckf | DIY-CNC Router Table Machines | 3 | 04-08-2004 11:35 AM |
