| CNC Wood Router Project Log Post your CNC machine building log here only. |
| Another one in the works.. Hello to all.. Time to "GetErDone". My name is Chuck and I've been lurking about for awhile reading and learning, tryin to come up with a working design. Since I seem to have alot of extrusion lying about, I figured it would be my best option for a frame. Did the Ebay thing and bought a bunch of worthless stuff, but did manage to get some THK slides and then bought some ballscrews from Reid. I chose to go with a moving gantry, the gantry uprights are 6061, 1/2" by 8 and 3/4" by 23 and 1/2". The frame worked out to be about 32 and 3/4 by 35 inches, if I can get a 18" cut, I'll be happy. The extrusion is by 8020 and is the 2020 and 1020 series. I'm using regular end connectors. The steppers for the x and y are NEMA 34 and are expected to give me 420 oz-in. They are rated at 4.8v @ 2.53a. They are 6 wire so I'll be running them in bipolar series. The z will have a 306oz (unipolar, not sure what bipolar will give) 6v @ 2a I haven't bought the drives yet but I'm sure they will be gekos. I did go ahead and get the "PC-to-route" breakout board. I will be using Mach2 and autocad. I started the assembly a couple days ago and took some pics along the way. Also took some pics of me trying to repair a ball nut that dropped a few balls due to my carelessness. the ideal was simple and it worked Tonight I will be working on the y and some pieces of the z, I'll take more pics along the way and I'm sure ask alot of question. take a look and Please offer your suggestions....this is all new to me and I'm making it up as I go..any advice is more then welcomed. Thanks in advance, Chuck
__________________ Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC. |
| This is where I'm at ...lot more to go..[IMG] [/IMG]
| And another...check out my gallery for more
__________________ Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC. Last edited by CNCadmin; 08-02-2004 at 04:11 PM. |
| Looks like a good start! Super stout frame, I like it. Last edited by DSL PWR; 08-02-2004 at 04:14 PM. |
| Looks to me like you got some nice stuff and you don't need much help either. Looks good! Marv |
| Thanks yall, I'll go through the pic sequence. [IMG] [/IMG]Pics 1 through 5. This shows the drilling of the access holes for the end connectors. the little drill jig from 8020 helps keep everything lined up. the #7 hole doesn't leave much room for error, sometimes I have to redrill with a 1/4 to get the 5/32 allen wrench to hook up with the button heads. Snug em down and it will be there for awhile.
| pics 6 through 8 show the finished rail and the feet ready to be taped...48 holes threaded to 1/4-20.[IMG] [/IMG] glad thats done! a cordless and a sharp tap makes all the difference....oh yea..magic-tap also helps.
| Here is the motor mount and the simple end bearing block. I will end up cutting off the wings on the motor mount. my ballscrew is only 36" with 3" turned down, so I ran it up between the center rails. I had already drilled the 1/4 inch holes on the side so it hooked up with the tslots in the extrusion...downside...I'm sure I will have misalignement somewhere...tweaking will be called for.
| Swiss Cheese! [IMG] [/IMG] Both sides were milled at the same time sandwiched together. plenty of 1/4 inch holes for whatever.
#10
| here are the cross support rails acad said they were 10.359375...somewhere around 10 23/64"...I'll cut these on the mill..thank goodness for the DRO..milled all 6 at the same time to be sure of assembly square-ness
#11
| remember that misaligned thing i was talking about..here it is [IMG] [/IMG] I didn't even notice untill I looked at this picture that my assembly marks are on the wrong end...that should take care of the misaligned motor shaft to the ballscrew I'll put that on my "to fix" list...moving on...
#12
| Lookin' My-T-Fine! That 2020 and 1020 is some pretty heavy duty stuff - and the 6061 plate fits in well. Did you draw out the design in autocad - or just sort of plunge in? Its such a machine to be proud of - others might take the same path if you had some dxf files. But, the nice thing with the "Big-Boy's Tinker Toy Set (80/20)" is you really don't need the plan - you can just start and see what fits where... Is your plan to cut metal with a really big router- looks like the rig for it. More pics cheers - Jim your post came in while I was finger fiddling on the keyboard - good alignment compensation!
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| Single line mode works well, Auto is not soo good?? | Darc | CamSoft Products | 16 | 10-26-2004 04:29 PM |
| Which came first, Solid Edge or Solid Works? | Arnie | General CAM Discussion | 3 | 09-15-2004 07:25 AM |
| sold works and 2d edming | wireguy | Solidworks | 4 | 05-22-2004 03:29 PM |
| Gibbs & Machine Works | cadman | GibbsCAM | 5 | 02-20-2004 11:15 AM |
| How does G 41, G42 works ? | BanglaTech | General CAM Discussion | 7 | 11-04-2003 12:38 PM |
