| CNC Wood Router Project Log Post your CNC machine building log here only. |
#25
).Be aware that if they are 24 VAC you will get >65 VDC after rectification (48*sqrt(2)). But you being an electrician this might not be news for you ![]() Arvid |
#26
| Thanks Arvid, I didn't know that, I guess I'm a different type of Electrician... I've never had to hook up two transformers in series before.. Anywho I went ahead and ordered a switched power supply...48vdc @25amps off of ebay. But thanks for the info. I'm learning new stuff everyday here
__________________ Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC. |
#27
| You're welcome ![]() The higher DC voltage is not because there are two transformers in series, but because of the rectification process. So one 48 VAC transformer would also produce some 65 VDC after rectification. 48 VAC refers to effective voltage, while after rectification you get the peak voltage (minus some diode losses and ripple). Arvid |
#28
I've managed to get some more work done on the y and z. Everything is connected on a trial until i can get some measurements. I'm ready to drop in the z axis ballscrew as soon has I get it turned down and the bearing holes bored. Maybe in the morn....its 100 degrees outside...east Texas quittin time [IMG]
#31
| Given the robustness of many of those components - WOW that's a MASSIVE clamp and router - you'll be ready to re-configure the bed to a 4x8 in no time! Well, new rails screws etc - but WOW - thats huge. Cheers - Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| Single line mode works well, Auto is not soo good?? | Darc | CamSoft Products | 16 | 10-26-2004 03:29 PM |
| Which came first, Solid Edge or Solid Works? | Arnie | General CAM Discussion | 3 | 09-15-2004 06:25 AM |
| sold works and 2d edming | wireguy | Solidworks | 4 | 05-22-2004 02:29 PM |
| Gibbs & Machine Works | cadman | GibbsCAM | 5 | 02-20-2004 10:15 AM |
| How does G 41, G42 works ? | BanglaTech | General CAM Discussion | 7 | 11-04-2003 11:38 AM |
