Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 02-17-2008, 07:52 PM
jimmyaz is on a distinguished road
My second CNC router out of Alluminum (bigger)
Hey Guys,
Just want to share some of my recent work, my first machine was out of MDF and cutting area is only about 12x15inches. I was quite limited, it was slow with 182oz nema and unbiopolar driver. Therefor I went ahead and look for new parts and want to build a bigger/better. I am currently shooting for 24x48inches cut area.
Here's the Z, I got this off ebay, have to take the whole thing apart and remove the coreless motor that came with it and cut off a bunch of stuff and use my mdf cnc router to cut a g-10 plate out... this will allow me to mount my own Nema stepper.
On the X axis, it was a hard decision whether to make it out of MDF again or aluminum. But I end up with aluminum purchase from HomeDepot. Total cost of aluminum for the X so far is 30.00.
I was thinking to mount the X motor inward drive by belt... Just simply to make it more compact, since I will be using the Nema 425oz and it long, having it on a side and moving back and forth would be crazy.... Do you guys think it worthed? By the way, will belt cause backlash?
Here's the pic so far.
ID:	53658   Click image for larger version
ID:	53659   Click image for larger version
ID:	53660   Click image for larger version
ID:	53662   Click image for larger version
ID:	53663   Click image for larger version
Old 02-18-2008, 10:13 AM
wow, 70 something view, no coments at all?
Old 02-18-2008, 10:59 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I like the Z-Axis where did you get it from? and cost.
The frame work may beed some extra bracing.
Joe
Old 02-18-2008, 11:03 AM
Hey,
The Z is found from ebay, 70.00... If you search for linear actulator on ebay you will find quite a few.
Yes, the X is not done, still need some corner cross support... But it pretty stiff right now, becuase of all the L and the way how it corner, it dead lock... I use all of my strengt and it only flex about 1mm.
Thanks for the reply..
Old 02-18-2008, 11:12 PM
Y update
More part came in today, gathering up the Y axis just to see how it look.
Yes, it bow, but I got a idea how to stop it... It start to look sweet now...
ID:	53748   Click image for larger version
Old 02-19-2008, 12:46 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Looks like you may need some X bracing in the back and sides of the Y axis.
And one thing you might try to support thoes long rails is to put wheel on the Y axis. Never saw any built this way but it would add support.
Good luck and keep posting pictures.
Old 02-19-2008, 09:58 AM
I got some open bearing that I will switch out, and the rail will be support it.
Old 02-19-2008, 10:38 AM
Mr.Chips's Avatar
Gold Member
A fully supported rail is the best way to go. Your Y and Z axis have very nice looking bearing so the fully supported one will now complement the others very nicely.
This type rail will be transferable if at some time in the future you decide to reengineer your CNC, this is a common practice for hobby as well as the experienced builders.
Just keep in mind what you will be cutting, weight of the finished gantry and the loads that will be on your machine.
You’re on the right track, keep up the good work.
Old 02-19-2008, 10:48 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Supporting the rails is the only way to go. The rest of the gantry looks good. Designed modular so easily changed later as Mr. Chips pointed out. Are you going to be driving both sides of the gantry?
Lee
Old 03-05-2008, 11:53 PM
Finally some progress
Sorry guys, been too busy with so many thing, finally got sometime and work on the machine.
Well, I ran into a lot of problem trying to get the X mount onto the Y, such a pain, I have to cut the linear bearing holder out, change it to a open bearing in order to support the rail.
So far so good, it moving pretty smooth, but still tons more stuff to do, here's some pix.
PS: I don't think I will drive both side, since it only about 26inches in witdh, one in the middle should do it... One big one. 3/4inches screw.
J
ID:	54863   Click image for larger version
  #11   Ban this user!
Old 03-10-2008, 07:40 AM
WannaMakeStuff is on a distinguished road
Thumbs up I like it!
Hi - it's looking good so far! The aluminium frame should be nice and light - and easy to add bracing to, wherever you find it necessary.
Can I ask what size angle you have used?
It looks like it mght be 1" x 1"' x 1/8" - good guess or not?
And what sort of (and size) bolts did you use?
  #12   Ban this user!
Old 03-10-2008, 11:06 AM
Hey,
Thank for the reply, you're correct, I do believe it 1x1x1/8. It seem strong enough, the frame is light but because of the Z axis is some really tuff and heavy it almost a good 15pound by itself, the frame is like 5-8pound.
But I don't mind it being heavy, as it will help to push down the Z when drilling into marterial.
As for the bolt, it just one of those 1/8 self drill bolt for metal.
Tags
cnc router
better, bigger cnc router? jimmyaz Open Source CNC Machine Designs 10 02-17-2008 08:01 PM
The bigger hammer Stepper Monkey Benchtop Machines 7 07-01-2007 01:43 AM
Air Cutting Stainless and Alluminum denmcdsk Laser Engraving & Cutting Machines 0 06-20-2007 05:00 PM
sherline or bigger? landongw Mini Lathe 1 02-19-2007 04:15 PM
My New Lathe; bigger/better Stevie Vertical Mill, Lathe Project Log 61 02-01-2006 10:32 PM
