| CNC Wood Router Project Log Post your CNC machine building log here only. |
#13
Size of the screw won't make it any stiffer. Clamp one side down so it can't move, and push on the other side. You might then change your mind back to two screws.
#14
| Your design screams for two screws. I can tell you for a fact that it will rack badly with a single screw. I was able to use a single screw on mine, but it is made of heavy steel and I built in adjustments to tighten the gantry up. I was able to load the gantry up tight enough to get it squre and eliminate racking. There is nothing on your machine sides that will take that kind of pressure. Those rails will flex inward just as easily as down and up. Two screws is really the only way to go. It will cost a little more, but you could run them both with one larger motor using a belt. That would likely be less than buying an extra motor and drive.
__________________ Lee |
| Tags |
| cnc router |
| better, bigger cnc router? | jimmyaz | Open Source CNC Machine Designs | 10 | 02-17-2008 07:01 PM |
| The bigger hammer | Stepper Monkey | Benchtop Machines | 7 | 07-01-2007 12:43 AM |
| Air Cutting Stainless and Alluminum | denmcdsk | Laser Engraving & Cutting Machines | 0 | 06-20-2007 04:00 PM |
| sherline or bigger? | landongw | Mini Lathe | 1 | 02-19-2007 03:15 PM |
| My New Lathe; bigger/better | Stevie | Vertical Mill, Lathe Project Log | 61 | 02-01-2006 09:32 PM |
