Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #13
Old 01-28-2008, 09:54 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Thought you might like to watch this video, it's not gunstocks, but could be.
In the video, check out what the guy is doing starting @ (frame 1:27).
He is teaching in the toolpath by hand.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
  #14   Ban this user!
Old 01-28-2008, 10:34 AM
chris l is on a distinguished road
Thanks for the video. What a machine. I like the way they program it. I plan to have the stocks scanned by another company. I haven't thought much about that part of the project yet. I'm not even sure how you tell the machine how to carve the stock from the solid model.
This is a very fun build and I appreciate the help from you all.
Thanks Chris
  #15   Ban this user!
Old 01-29-2008, 05:46 PM
harryn is on a distinguished road
If I were serious about making a bunch of high quality wood parts like gun stocks as a business, I would really look hard at pre-build commercial tools like that one. The software cost alone to get you from scan - code - running is non trivial (thousands).
A machine like that could take a 1 - 2 man shop and make it competitive with much larger firms. The ability to do that kind of scanning is something you will be drooling over for a very long time.
8 x 10 hp spindles with auto tool changing is just an amazingly valuable capability - if you can move that many parts along.
If you can get that thing for $ 200 K, you should seriously not waste your time on a home built for a business use.
  #16   Ban this user!
Old 01-30-2008, 10:10 PM
I know for a fact that even some of the high volume shops dont have the budget for 200K machine. And neither do I. I have to start out with the small one and work up.
  #17   Ban this user!
Old 02-10-2008, 08:57 AM
Here is a pic of the frame
Old 02-10-2008, 09:57 AM
Switcher's Avatar
Moderator
Looks Strong!
Glad to see your still working on your project, you still planning on 3 routers?
Old 02-10-2008, 10:00 AM
Switcher's Avatar
Moderator
Also I only posted the video, so you could see the multiple spindles, & toolpath.
I wasn't thinking you should buy one, I doubt many folks that could afford that machine, are hanging out in a diy forum (maybe I'm wrong?).
  #20   Ban this user!
Old 02-11-2008, 08:41 AM
The comment was for Harry that recommended buying this type of machine.
I enjoyed the video, very cool. I liked how they programed the tool path. I will probably have the stocks scanned to get the solid model. I know it's down loaded into a CAM package but I'm not sure how the tool paths will be programed.
Old 02-12-2008, 12:26 PM
Gold Member
JFettig is on a distinguished road
Hey Chris, you might remember me from your thread at homegunsmith
I just made this on the CNC router at work on sunday, its just a test piece made of mdf, I'm making changes to the design and I plan on making one out of real wood soon.
Just some inspiration
I am also designing a stock making machine, If you need help with the design I'd let you borrow some of my ideas, I have a 4 axis setup for my mini mill that I plan to steal off of it to make this thing. I'm making it to be cheap, rigid and relatively accurate(it'll take some tuning but it should be feasible).
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
  #22   Ban this user!
Old 02-17-2008, 09:54 PM
CNCfun&games is on a distinguished road
Gun Stock Router
Enclosed are photos of a pantograph router.
A gunstock was placed in the left position and the stylus was moved over the surface and replicas were machined in the middle & the right position. The Crank on the front of the machine turned the Master and the 2 wood blanks simultaneously.(like an A axis)
The configuration is similar to what might be expected in the design of a CNC machine.
Thomson Rails on all three axis. A counterweight on a lever arm neutralized the weight of the Z axis.
ID:	53669   Click image for larger version
ID:	53670   Click image for larger version
ID:	53671   Click image for larger version
Rifle Stock BobWarfield Rhino 3D 2 02-19-2007 12:27 AM
3d stock model camtd EdgeCam 2 10-19-2006 11:36 PM
stock definitions (again!) shawncnelson Mastercam 3 05-02-2006 04:53 PM
Boards in stock? slamman Hobbycnc (Products) 5 02-11-2006 04:45 AM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 09:16 PM
