| CNC Wood Router Project Log Post your CNC machine building log here only. |
After several years of reading and watching everyone build awesome machines, I am finally getting off my butt to build a CNC machine. I realized I have a ton of Bed Rails sitting in storage. I tried looking for others that used bed rails but only found one reference here: Bed Rail Steel CNC Router ...but I don't want to use any wood. All metal and I need to keep the cost low. I am looking at building a 4' X 4' . I really like how Haydn built his: My First Router, Built in Steel and would like to do something similar. Anyone know how I could incorporate the bed rails into this project?? |
__________________ Free DXF Files - Vectorink.com - myDXF.blogspot.com |
| I think you'll find that bed rail is some pretty hard steel, probably approaching spring steel. Think about the pounding (no pun intended) it has to take on a nightly basis and keep in mind that some humans have a hoof weight of 300 plus lbs! Pretty tough stuff. I remember trying to drill hole in some, once upon a time!
__________________ "Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson |
| Maybe, I could rent a plasma torch and cut through it. I don't want to spend a huge amount of time/frustration doing the basics with the stuff. Though, it sounds like it would be sturdy enough to do the job. |
| If you use a torch you'll ruin the temper and maybe warp the rails. You can use a carbide tipped masonry bit, just sharpen it by hand real carefully or you can get 90 degree drill point end mills economically. check page 23 here http://www1.mscdirect.com/CGI/NNPDFF?PMCTLG=40&PMPAGE=1
| A bed rail is that piece of angle stock that joins the head board to the foot board and supports the springs or box springs.
| How many rails? | sp1nm0nkey | Linear and Rotary Motion | 2 | 10-21-2007 02:47 PM |
| Design of plasma table, high rails or low rails? | Apples | CNC Plasma and Waterjet Machines | 3 | 12-18-2006 03:21 PM |
| THK rails | wakeboard | DIY-CNC Router Table Machines | 2 | 01-21-2004 05:13 PM |
| Anybody seen or used these rails | xairflyer | DIY-CNC Router Table Machines | 4 | 01-20-2004 04:20 AM |
| Can I Cut THK Rails? | samualt | DIY-CNC Router Table Machines | 5 | 09-15-2003 05:45 PM |
