Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 01-19-2008, 04:37 PM
LazyMan is on a distinguished road
Smile All aluminum Router-Ballscrews, extrusions, linear slides
Well here is my build log.
Specs:
X-travel = 31 inches
Y-travel = 18 inches
Z-travel = 6 inches
The linear rails are the supported 20mm 55" rails from VXB bearings. I bought a set of three along with some extra bearings and cut them to the lengths I needed.
The aluminum extrusions are the 30 series from bosch rexroth. All aluminum plate is mic6 tool and jig plate. Every part has been machined on a mill to make sure everything was all nice and true.
Please excuse any mess and clutter in the pics as my "workshop" is the floor in a closet sized dorm room.
Well lets get started
Old 01-19-2008, 04:57 PM
Table Assembly
Heres the table assembly. I used a large "scrap" of MIC6 to as a surface plate to assemble things. A nice square also helped to get things nice and true.
ID:	51146   Click image for larger version
ID:	51147   Click image for larger version
ID:	51148   Click image for larger version
Old 01-19-2008, 05:09 PM
Gantry Assembly
So far, everything has gone pretty nicely.
ID:	51157   Click image for larger version
ID:	51158   Click image for larger version
ID:	51159   Click image for larger version
Old 01-19-2008, 06:38 PM
Greolt is on a distinguished road
For a lazy man you have made a pretty good looking start.
Keep the pics coming.
Greg
Old 01-19-2008, 06:53 PM
Ballscrews
Here are the ball screws. I had the machine the ends down to size. The fixed bearing end was machined to fit NSK Angular Contanct bearing blocks that I snatched from ebay.
The mounting flange is fixed to the ball nut with two screws. I would have used setscrews but my box of 100 mysteriously dissappeared. There are six or so curved spring washers between the two ballnuts. The ballnuts are then tightened together to achieve the preload and then the clamp is used to prevent the nuts from spinning loose, thus maintainining the preload.
For those who are currious. The roton ballscrews are pretty good although not quite as good as I hoped. When too heavily preloaded they don't spin as freely as I would like. Im not quite sure how much they are being preloaded and am not sure what exactly to expect, not to mention I can be alittle obssesive about small details sometimes. I will evaluate their performance when I actually run the machine.
ID:	51165   Click image for larger version
ID:	51166   Click image for larger version
ID:	51167   Click image for larger version
Old 01-19-2008, 07:02 PM
Where is the lathe? Under the bed?
Old 01-19-2008, 08:47 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Looks good man!
Old 01-20-2008, 02:36 AM
Talking
lol. For those who are wondering, I'm a university student and have "free" access to a machine shop. The machines are fairly nice but I generally use my own cutting tools that I have collected from ebay beacuse many of the shop cutting tools hack and rub the work as opposed to actually cutting it. I used the wagon you see in the pics to haul my stuff back and forth.
Old 01-20-2008, 04:09 PM
Some more pics. Im going to use 203v geckos and some keling 425oz steppers. Im currently waiting on a CandCNC combo package to arrive but I heard that they are currently backordered so it might take a while.
ID:	51264   Click image for larger version
ID:	51265   Click image for larger version
ID:	51266   Click image for larger version
New Super Wide and Flat Aluminum Extrusions! carolpratt Product Announcements & Manufacturer News 0 07-02-2007 11:07 AM
Linear Slides pbunnstf DIY-CNC Router Table Machines 3 07-18-2006 09:47 PM
Linear Slides v/s rail slides bryanrabb DIY-CNC Router Table Machines 4 03-27-2006 09:45 PM
Linear slides for z axis router kent chasson Linear and Rotary Motion 4 10-26-2005 01:17 AM
Aluminum Extrusions Woodie1 DIY-CNC Router Table Machines 2 09-13-2003 01:38 PM
