Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
  #13   Ban this user!
Old 02-27-2008, 09:37 PM
thetrick's Avatar
thetrick is on a distinguished road
So I have built my ghetto Z axis. This is the last part I am building out of MDF in my quest to user better materials. The first think I plan to make with my router once it is running is a new z axis. I got my steppers from Probotix, and started building the drives. I made shaft couplers out of some hex aluminum I scavenged.
The pillow blocks ended up being a bit of a challenge. First I had 2 pillow blocks per drive, then I went to one with the other end of the shaft using the stepper for support. I plan to fix this too once I have the router running and can make more accurate parts.
I found a quarter sheet of ¾ cabinet grade birch plywood, and have been using that to make some parts. It’s much stronger and actually has some structure, unlike MDF.
ID:	54320   Click image for larger version
ID:	54321   Click image for larger version
  #14   Ban this user!
Old 04-15-2008, 09:00 PM
thetrick's Avatar
Ok so a lot has happen since last time. First off it’s now running. I got my drivers and motors from Probotix. The router I am using is a piece of junk and will certainly die soon.
I had a bent x-axis lead screw that I had to replace, and then I needed to rebuild the x-axis stepper mount. I had some issues with mid-band-resonance stalling the steppers, but fixed that for the most part by changing the driver from 1/8th step too 1/2 step. I would like to get some 2 turn acme screws soon so that I can speed things up.
It is a very solid machine except for the z-axis which works, but had more play in it than I would like, plus I build it with too little upward clearance to the bearing block. Basically it can extend 3 inches below the table surface, but only about 3 inches above it too. Oops
I am in the process of enclosing the lower cabinet so to keep out the dust from all the electronics.
ID:	57805   Click image for larger version
ID:	57806   Click image for larger version
Using steel instead of wood for construction ChristianW DIY-CNC Router Table Machines 1 07-04-2007 07:55 AM
New CNC wood router. WayneHill Commercial CNC Wood Routers 2 12-27-2006 03:07 PM
How many MM per rev for a wood router? WayneC Linear and Rotary Motion 1 06-26-2006 04:53 PM
First Cnc Wood Router ahmed JGRO Router Table Design 4 05-04-2006 12:19 PM
Milling Steel with a Retroed Wood Router whiteriver Commercial CNC Wood Routers 2 07-08-2005 06:27 AM
