| CNC Wood Router Project Log Post your CNC machine building log here only. |
Sorry, couldn't find anywhere to best post this question... Where can I find fiberglass sheet/board/plate that is arround 1,2,3mm thick? It doesn't have to be in metric, inches is fine but arround that size. Within the USA offcourse. Thanks |
| A Google search for FRP sheets found a bunch of sources. If you are looking for the unclad circuit board material search for FR4 or G10 sheets. CarveOne
__________________ "A $1,000 electronic device will almost always protect a ten cent fuse." |
| Wax a peice of glass with mold release wax per the dirrections on the can, lay out 1.5 oz fiberglass mat on it and wet it out with polyester resin or marine epoxy (with proper hardner added). Use a dabbing motion if you use a brush or use one of the throw away paint rollers. Don't use more resin than needed to wet out the fiberglass. Use more layers if you need it thicker. Get out all air bubbles with the roller or buy a slotted layup roller. If you want it a nice shiny color use a coat of gel coat in the color you want as the first layer against the glass plate then do the above after it hardens. It will look as good as the finest boat you ever saw. |
| RFQ: ABS Sheet CNC or Waterjet? | ncmrfixit | Employment Opportunity | 6 | 05-11-2007 11:21 AM |
| cnc router out of 8x4 sheet mdf | rob gibbons | DIY-CNC Router Table Machines | 5 | 09-27-2006 03:41 AM |
| Calibration sheet | brtlatjgt | General Metal Working Machines | 1 | 09-25-2006 12:04 PM |
| sheet cam prob | fastimes | SheetCam | 0 | 07-28-2006 10:11 PM |
| how to mill 7075 T6 sheet material | gcamlibel | General Metal Working Machines | 11 | 09-08-2004 02:06 PM |
