| CNC Wood Router Project Log Post your CNC machine building log here only. |
#73
| I would like to know why you went with servo's instead of steppers? Again great job and good luck Thanks Txfatboy, from the various threads posted on the site, I realized that servo's suited my needs better (higher rpms, more powerful among other things) and as a big plus, I got my motors dirt cheap. I am amazed that the spade bit worked for the bearing surface. Will there be a set scrrew holding the bearing? What type of saw blade did you use in your table and miter saw to cut the aluminum? I am to the point that it is time to start construction of an aluminum machine as well. Well mark, I also was surprised the spade bit cut alum so well. When I first did it, I was getting these wonderful strips of continueous aluminum ribbons.I plan to use a set screw to hold the outer raceway of the bearing in place. As for the saw blade, I used a triple chip 80 tooth blade in both my tablesaw and mitersaw to cut the aluminum. These type of blades cut aluminum (as well as plastic) very well. Gerry mentioned in a pervious thread that a negative rake angle on the carbide tooth cuts a little bit better. I do know that it helps particularly on a mitresaw. Hey chronon1, It really is alot of fun building a cnc machine and quite a learning experience. I also think this is a good sized machine for a hobbiest, you can cut a wide range of things and still have a manageable footprint. I plan to continue posting plenty of pictures and also detailed information as to my thinking on several parts. Thanks for reading my posts.
__________________ -Patrick _____________________________________________ measure twice, cut once - a good rule for everything |
#77
| Hello Pat, I see a fellow wood worker has been bitten by the CNC bug. It's a lot of fun and metal construction is more of a challange than wood at least for me. Really like your design, the extruded alum box on your Y axis will be super strong. And you will be able to expand your woodworking skills with a CNC machine. Keep us up to date on your progress. Hager |
#78
| Hello folks, sorry I didn't communicate for awhile (a series of events happened with family, friends and my employment which sort of took priority for a while). I'm hoping to get back to building my machine sometime in January. I especially look forward to catching up to all the posting and progress that many others have made with their machines. Enjoy your holidays and new year. Pat
#79
| Hi Patrick, Hopefully everything is going well with you and yours... When you decide to come back and start working on your CNC router, we'll be here for you.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
#80
| Hi Patrick I looked at the Automec web sight. The motor specks say 46.5 in/oz @ 3 amps can you really pump 20 amps through that motor and get 360 in/oz of torque from that motor? And 3 motors at 20 amps plus your spindle motor seems like a lot of amps for that machine. Or am I not figuring this right? |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 09:04 AM |
| Heads Up - Article about building CNC Milling Machine | samualt | CNCzone Club House | 3 | 06-13-2005 02:43 PM |
| My CNC Machine and Questions | Davedbq | General Electronics Discussion | 2 | 01-22-2005 09:14 AM |
| World's Cheapest CNC machine @ $100?? | SuperCharg | DIY-CNC Router Table Machines | 2 | 09-15-2003 07:39 AM |
