Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 11-19-2007, 02:11 PM
multiplex is on a distinguished road
another first time build!
Hello everyone. I've been lurking the forums for a little now, and am about 1/2 way done the construction of my first table.
I'm planning on learning the hard way, and am sure there will be some design flaws along the way.
The main construction of the frame is 2" x 2 1/2" angle iron. Mounted underneath are two 55" vbx 20mm rails. The main gantry is contructed from 3/4" pvc.
I realized my first flaw this weekend after assembling some components. The Y axis has alot of flex in it. The unsupported 20mm rods can't handle the span.
So those are on the way out, and will be replaced with another set of supported 20mm rails.
Overall travel will be 49 x 44 x 8
movement will by by 425oz steppers, and 1/2"-10 2 start acme rod.
Let me know your thoughts!
Old 11-28-2007, 10:19 PM
well i've gotten a little farther, although i still need to get a better camera.
z axis is 95% complete, and i'm just waiting on the nuts from dumpster cnc. I'm going to be counter weighting the head to reduce the load on the stepper / screw. i considered constant rate springs, but want to balance the weight that is hanging off the front of the rails.
still need to convert the x axis to support rails. rails are here, just need to find some time
Yohudi's Build log - Time to get stuck in yohudi CNC Wood Router Project Log 79 09-25-2008 01:41 AM
My Second Router Build This time Joe's CNC Model 2006 Catapultsup Joes CNC Model 2006 4 08-17-2007 11:17 AM
milling time (not to be confused with hammer time) barefoot0 G-Code Programing 4 05-02-2007 07:18 PM
DIY - Build CNC for the first time XenC Open Source CNC Machine Designs 4 12-21-2006 06:48 AM
3rd CNC ROUTER BUILD time to get serious. Oldmanandhistoy CNC Wood Router Project Log 16 02-22-2006 05:41 PM
