| CNC Wood Router Project Log Post your CNC machine building log here only. |
#145
| I've also realized that I'm going to actually need limit switches on this router. Before I could stall the motors when I ran out of travel... Now I can't stop the gantry by hand, and don't want to see what happens if I let it crash into the end of it's travel.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% Last edited by mvaughn; 06-18-2005 at 07:29 PM. Reason: small typo correction |
#146
Anyone remember me? It's been a loooooooooong time since I've been able to put any work into my cnc router. I'm determined to get this thing working before it's 3 year anniversary arrives. I think I'm ready to finish it off so I can put it to use building a modified Joe's or Lionclaw router. Looks like there is a whole new crew of guys here and a mix of older familiar names as well. It's good to be back.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
#149
| Lol... it's good to be back. Last week I dug my cnc router project out of my rented storage unit. I've moved 3 times in the past year and didn't want to pack it around. I'd forgotten how heavy MDF can be. I'm going to have to take inventory on it and see what I need to do to finish it up. If memory serves, the x, y, and z axis are complete. The electronics are complete. I need to build a PC for mach3. I need a refresher course in CAD, CAM and gcode. I've been eyeing Cambams cam software and think I'll give it a try. Is anyone else using it?
#150
| I made a little progress on getting the router all setup. I was dying to get it all hooked up and see if it still moved. Knowing my luck it would have seized up after being in storage for over a year. The good news is that it still works!!! I know the picture is a little blurry. All I have is a cell phone camera at the moment. It's 100% complete except for making sure it's square and devising some way of holding parts down. Now if I can only find my endmills...
#151
![]() Good to see you back on the case! MikeF's got his up and running...right...we just need to give JavaDog a bit of a stick poke now... |
#152
| I'm self taught when it comes to CAD and I find your cambam program very intuitive. I did have a problem with milling a pocket. It seemed that it left a little triangular piece when cutting out a T-shaped pocket. I can't wait for your next version. ![]() What? JavaDog where ya hiding?
#153
| Usually, reducing the stepover distance will make these go away (stepover is a % of the cutter diameter). Setting the ShowCutWidths=True machining property will help you spot these. So what you planning to make next? |
#154
| At the moment I'm putting cambam through its paces cutting out all the parts for my 2nd router. I'm too focused on the next router to make anything else.
#155
| I see that you have connected the HP steppers to the RED box and added connectors to the steppers. What is the sequence for connecting your steppers? I have the same ones, but not sure of the wiring since the colors don't seem to match any diagrams that I have seen. |
#156
| I also have those exact same steppers. Bought them on ebay last year after I stumbled uon the Zone and got bit by the bug. Got side tracked for a while but have started planning again. Any info you can give on hooking them up will be greatly appreciated. Are you still using the 24V power supply? I have two 24V 7.2A power supplies I got from ebay that were pulled from some kind of machine, although I need to check the actual output. I was told I would probably need higher volts. How has yours been doing with 24V? Also, did you ever upgrade to one of Phil's drivers like you had planned? That is what I was thinking about using for mine. I am thinking about doing a machine based on the one at www.buildyourcnc.com with a few changes inspired by things I have seen on the Zone. I was not sure if the motors would be big enough for it but your machine is slightly larger than what I have planned so I am enthusiastically hopefull. |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 09:04 AM |
| Heads Up - Article about building CNC Milling Machine | samualt | CNCzone Club House | 3 | 06-13-2005 02:43 PM |
| My CNC Machine and Questions | Davedbq | General Electronics Discussion | 2 | 01-22-2005 09:14 AM |
| Interested in NY/NJ CNC machine demo... | jasonsp6 | General Metal Working Machines | 3 | 07-23-2004 12:47 AM |
| World's Cheapest CNC machine @ $100?? | SuperCharg | DIY-CNC Router Table Machines | 2 | 09-15-2003 07:39 AM |
