| CNC Wood Router Project Log Post your CNC machine building log here only. |
Hey guys, I've been visiting this site for awhile and have started planning my own CNC. First off thanks to everyone who comments and shares their wisdom/knowledge with all of us just beginning this obsession. The wealth of knowledge is a little overwhelming but very appreciated. Ok now down to business. I'm planning on constructing the bed with a usable area of about 24" x 36". I've been saving some 30mm linear bearings (open style) for the y-axis and a few 16mm bushings/bearings for the z. I wanted to use supported rail but don't want to spend $$$ for the manufacturers rails. I was thinking about some drill rod, or stainless steel shaft. It needs to be tight tolerances...any ideas/suggestions? Know any good websites to order from? Also should i think about using thick wall tubing instead and make some supported rails myself, i don't have a milling machine or anything, I'm a furniture maker so it needs to be fairly painless for me. Thanks for any comments, I'm excited to finally start seriously planning. |
| You may want to check out www.buildyouridea.com. He made some supports for rails with a lost foam casting process. I followed his work to design my linear bearings, only wish I would have stuck with the supported shafts. My cnc router is almost done and I'm already planning a way to change the unsupported x axis. |
| bobf, I've definitely gone through joes build, it's been awhile but I think he still uses drill rod as the rail system and i think he orders it from Enco. Problem is that they don't sell much drill rod in metric, particularly 30mm. It is a good idea, I just need some leads on where to get some the size i need. I tried searching the internet for over 2 days with no luck. Metric is rough to find that large. Texas, I have also seen that build as well, great work on his part. That was my other idea, using tubing instead of rod, that way i could make a T-supported railing that was easier to attach, less expensive but offered more rigidity than an unsupported 36" rail. Has anyone tried using found rod/tubing with THK, NB, etc high precision linear bearings? Will it work or will i be disappointed with a sloppy/too tight fit from the tolerances? Thanks for the replies |
| Praire Dogn, Look at post 92 in this thread for an alternative to round tails. Alternative to round pipe. |
| New guy with a couple of questions | blackhollowmfg | CNC Plasma and Waterjet Machines | 5 | 01-31-2007 01:58 PM |
| saying hello with a couple of questions | JonC | DIY-CNC Router Table Machines | 29 | 06-27-2006 12:57 PM |
| Newbie questions. Planning a new machine. | space_case | DIY-CNC Router Table Machines | 17 | 08-02-2005 04:50 PM |
| just a couple questions from the new guy | mik32176 | General Metal Working Machines | 0 | 04-10-2005 02:04 AM |
| Couple of Questions | ccm | General Metal Working Machines | 4 | 08-26-2003 09:31 PM |
