Page 1 of 4 1234 LastLast
Results 1 to 12 of 44
Thread: First Router Build - 4x4, steel, R&P
    Sep 2005
    OK, so like many others, I've been lurking for a long time, and have had some help from you guys which has been great! So now I've finally got some time on my hands to start my router. My shop has been in need of a cnc for some time now as my business produces some difficult parts to make by hand. I also plan to start making some precision templates for my dealers.
    Purchased all the steel locally plus rumaged through their scrap bin for odds and ends.
    Ordered the following...all on it's way:
    -55" supported hardened rails w/pillow blocks from vxb.com (x axis)
    -425oz Xylotex 4 axis kit (2 for x axis)
    -3 49" racks (part# 200012) from stdsteel.com
    -8mm ID ball bearings (y and z axis)
    Hoping to cut:
    -49x49x6"
    -Mostly MDF, some polycarbonate, acrylic, light aluminum cutting
    Plans:
    Racks on the side of the table to drive the steel gantry. The Z-Axis will be MDF for now because I have no way of *inexpensively* machining the metal to make mounts... etc, just basic metalworking tools. Still need to buy a PC router, a cable organizer, and misc. nuts and bolts and extras.
    This machine has grown from the original design of a 12x12 all MDF/acme router into what it is. I've drawn up (with my limited autocad skills) two different designs which this has changed from, so I'm just kinda wingin' it.
    2 questions before ordering any more parts
    1. Where do I get gears for my racks?
    2. Should I gear down the motors or use a direct drive?
    OK - Pictures!
    The metal from our local fabrication shop.
    All welded together. My poor 944's new home is outside the shop...
    The start of the sides of the gantry.
    May 2006
    Quote Originally Posted by cxixer View Post
    The 200010 would have been a better choice IMO
    I would gear them down using belt and pulleys. However have a look at the Mechmate. They direct drive their pinions
    Greg
    Nov 2006
    Barbados
    I'm interested in a steel router of this size, will be following up on this thread.
    Sep 2005
    More pictures coming soon...
    About the gearing issue.. How much should it be geared down? 1:2, 1:3 ? What would the benefit be?
    I'm getting ready to order the gears and am not sure what to get.
    Thanks!
    By the way -
    Greolt - your blue router is a big inspiration of mine. Absolutely an awesome design - and your input is always appreciated!
    May 2006
    I use Geckos but there are quite a few blokes over here using the Xylotex driver and they say that the practical speed you can rely upon is about 300 rpm motor speed.
    My thinking when deciding on gearing ratio was as follows.
    Belts and pulleys are not cheap and because of the compact design of my mounts it was not desirable to change this part once made.
    In contrast the pinions are quite cheap and easily changed if ratio did not work as well as hoped.
    The theory is that it is best not to go below 20 tooth with my size rack. Upper limit does not matter.
    So I started with 24 tooth pinions and 4 to 1 reduction ratio on the pulleys.
    This has worked very well for me so no pinion size change was needed. This is approx 100 steps per mm (1/10 micro step)
    I'm using similar motors to what you have ordered and with Mach running at 25000hz I can rapid at 7500 mm per min all day with very brisk acceleration setting.
    That's about 375 rpm. Remember I'm using Geckos not Xylotex.
    If I bump it up to 60000hz it will rapid at over 15000 mm per min but this is way too fast for my comfort.
    Remember that my machine is smaller than yours so it is not as far to go before reaching a limit.
    Might also be worth getting an idea from Xylotex what a reasonable top RPM can be expected with that combination.
    Hope this helps, Greg
    Sep 2005
    up to 14 hours of labor...
    Those rails are well worth the money, I can move this ~40lb gantry with little more than a light breeze.
    Any comments, suggestions?
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    kEEP IT UP .. I AM CONTINEOUSLY WATCHING UR PROGRESS.... I WANA SEE THIS MACHINE RUNNING MAKING FLOWERS AND UR DREAMS IN REALITY..:_)
    Apr 2007
    Hi, I am studying different designs and component costs. Could you tell us about how much the rack and pinions costs ?
    Registered planekrazie's Avatar
    Apr 2006
    Looks Great
    Looking Good. I just sold my cnc a few weeks back to a great fellow member of the zone. Now I am looking to build another one. I am gonna follow this build. It looks like what I had building up in my head. Gonna be a great looking router. I am gonna mount my rails on the sides about 6" below the table surface. There is another router a member here has built and It looks great. Hope he dont mind if I post one of his pics. But here is kinda what I had in mind.
    Steve
    Attached Thumbnails Attached Thumbnails First Router Build - 4x4, steel, R&P-full%2520machine.jpg
    Sep 2005
    Quote Originally Posted by harryn View Post
    The racks cost 16.50/ea from stdsteel.com - with shipping it was $74 for three racks. They don't accept credit cards which is odd. And they don't sell gears, so I'm still sourcing them. I need to order the gears and an acme screw for the Z axis and I should have everything to complete it.
    I'm up to 20 hours of labor so far. Kinda had an oops moment, didn't take into account the rail and bearings for the lower gantry support and ended up with very little room underneith, so it's gone. Thats what I get for building without much of a design. It is very sturdy with just the top support, and now has rails on it. This thing is so smooth, it could probably be driven on just one side with no problems.
    Apr 2006
    Pakistan
    It will better to use Ball screw in place of acme rods:-)
    Nov 2006
    Barbados
    Quote Originally Posted by planekrazie View Post
    Steve
    I had my eyes set on this one for a while too, indeed a sturdy looking and attractive design, and the speeds are nice too, did you see the videos he has of it?
    Cxixer, looking good so far, you know how we in the zone love those pix, keep em coming.
  • Page 1 of 4 1234 LastLast
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. My Steel Frame Router
      By epineh in forum CNC Wood Router Project Log
      Last Post: 07-05-2009, 10:27 PM
    3. diy cnc router in steel, any one try it yet??
      By .xXACEXx. in forum DIY CNC Router Table Machines
      Last Post: 10-04-2007, 05:17 PM
    4. Steel C-channel Build - Questions and pictures
      By olskool in forum DIY CNC Router Table Machines
      Last Post: 07-07-2007, 02:31 AM
