Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 09-22-2007, 09:13 PM
rc_flyer is on a distinguished road
Solsylva 24" x 48" 1/2"-10 acme upgrade
Hey Carve_one, Graham and all.....
the solsylva acme upgrade is basically done, and producing parts!! Have run for a couple of days at X=60IPM and y=65IPM to check for loose parts etc.... Finally found all my strange intermittent problems where do to a weird issue with the puter I was running Mach with. Didn't realize that was the problem til I talked to Art.. The issues almost went away with the Acme upgrade, but were still there very intermitently. No probs at all since I changed out the computer.
Now that it seems happy for a couple of days, I decided to see what it could actually do now. Just did a few air cuts of the contract job I'm doing, after bumping up the max speeds a lot. I set the Y up to ~100IPM, and the X up to 90IPM, accel at 10, and all jogs semmed happy, much to my surprise. It ran almost half way through the job before the Y coughed... WOW!!! set them both to 90 and it ran all the way through.. Gonna back off to 80 to actually run the job some more. Still a little gun shy after my weird problems...
These are the following changes from the plans after a year of use....
1) Xylotex board with 269oz steppers, 24" x 48" cutting area.
2) NEW! 1/2-10 acme lead screws from Enco on all axis, no turned ends, using all 0.5" ID hardware, including bottom Z bearing added.
3) NEW! Steppers on Y and Z coupled with short belts, not direct, with 15T pulleys.
4) NEW! DumpsterCNC AntiBacklash nuts.
5) NEW! Doubled up both of the 1x4 end plates to limit vibration, especially on stepper end.
6) 1.5" x 2.5" Steel tubing for sides and gantry. (sure glad I did that, and to think I only used those because they were free LOL)
7) Added dampers, since it really made the slower cutting speeds sound much better.
Now to slowly change the rest of the wood to metal...
Didn't go the multistart to keep upgrade price down. Didn't go ACME originally went 1/2-13 allthread, which was a disaster, since I didn't know about Enco 1/2"-10 prices, actually cheaper than allthread. LOL. I'm trying to forget the allthread trouble shooting time, cutting it out of my life.....
All that said, Does anybody out there have an extra foot of 1/2"-10 5 start, or 1/2"-8 4 start they didn't use from a longer piece? want to change the 1/2-10 on the Z axis to this to help with the moving the weight up and down issue. Some contract stuff I'm cutting has about 605 up and downs in each cut, and the Z is the weak link from a speed standpoint right now with the 1/2-10 single start.
Or else does any know anywhere on the web that will sell a 12" piece? everywhere seems to have a $50-$60 minimum order, and I only need 12", about $9 worth...
More on the upgrade and some pics maybe tomorrow, and will upload the gcode for part of the contract job, since it is a VERY good test of the machine. 55 sets of 11 holes, 605 in all, on a 2'x4' sheet of luan..
Don
www.eurekaaircraft.com
Old 09-22-2007, 11:20 PM
justCNCit is on a distinguished road
Im building a machine very similar to yours. Same screws, but 400 oz in motors w/xylotex controller. 4' x 6' table
i counted on problems with moving z axis up & down, my question to you is how do you expect to move the z axis with multiple start screw? Faster?? Don't the step motors have enough trouble just moving all that weight?
My plan's to use 400oz in steppers on the z axis with 1/2-10 screws. Would you suggest sticking to this plan?
Old 09-22-2007, 11:31 PM
vcooney is on a distinguished road
Try Widgetmasters ebay site I know he has 6" to 18" acme screws. Go to
www.widgetmaster.com and click on his Ebay link.
Vince
Old 09-22-2007, 11:56 PM
Justcncit....
Going to a lower pitch thread gets more movement per rev of the stepper, so more speed will be achieved since you will get more speed at the rev that works now, ie at the same torque point of the stepper. Same reason you get more speed from 1/2-10 than you do from 5/16-18. Steppers lose torque as the speed up, so you try to get more movement at the same RPM. The stepper doesn'y know you changed the lead screw. And yes before anybody screams, it won't be the theoretical increase of 5x the speed, going from 10TPI to 2 TPI, due to intrinsic losses, but it should get me to where I want to be. I don't know if I explained this right, but the jist is right. Talked to David Steele, he has tried it with 3/8"-10 2 start, and it definitely helped. Time will tell.
I though about making some kind of counter-weight, similar to the way they do the harbor freight/grizzly mill upgrades, but the Y axis moving opens up a real can of worms doing that, plus the space issue.
Don
Old 09-23-2007, 12:00 AM
vconney, tried the link and there isn't a page there now. Do you have any links to his ebay stuff, or his exact ebay name?? thanks
Old 09-23-2007, 01:07 AM
ahren's Avatar
ahren is on a distinguished road
rc_flyer,
I have an extra 3' length of 1/2-10 5 start. It's slightly bent, which is why it's extra. However, I'm guessing there's probably a foot of it that's straight. I'd be happy to send it to you for free so long as you pay shipping. I'm in a good mood since I got my machine moving tonight .
Oh, and on the subject of getting higher speeds -- higher pitch ACME has significantly better efficiency (sometimes up to 70%, compared to only 20%) than single start 1/2-10. This means that you basically get your extra speed for free! Well, not quite -- you're still trading off resolution. You're also right in saying that it's good because it keeps the stepper turning slower, where it has more torque. Case in point, with the same motors, I went from 200 IPM on single start to 700 IPM (!) on 5 start.
Anyway, PM me your address or send me a note through my website and I'll hook you up with the ACME rod.
Ahren
www.cncrouterparts.com
Old 09-23-2007, 06:11 PM
First part pictures...
Here are pictures of the lead nut mounts. They mount to 1" alum angle that replaces the 3/4" used with the smaller rod, to give room for the 1/2" rod. No pictures of those before mounting , but they are simply wider versions of the original, same holes and slots. Same mounting procedure. I tried to keep this simple, just slightly bigger.
The DumpsterCNC AntiBacklash nuts are used through out. They are very high quality pieces. I ordered the round flanges since I wasn't sure how to mount them till they arrived.
The mounts are made from 2" angle, about an inch wide, so they would be long enough for the screws to reach both slots, as before. The holes are 5/8". One end is cut down to match the shape of the AB nuts flange, as shown. The AB nuts flange is sanded to fit the mounts after mounting them. I used 8-32 bolts, with holes in the mounts tapped. The holes for the adjustment bolts are tapped in the mounts as before. All adjustments are as before.
The Z mount is trimmed down much further to get it to fit in the very tight space. It is barely wider than the barrel of the nut. I moved the Z axis trucks out closer to the edge of the box to get more room behind.
Other info: I used .5" ID- 1.125" OD bearings, (R8ZZ from Ebay) so new bearing mounts had to be made. I also used .5" ID pulleys from SDP and ordered Acme nuts from Enco along with the rods, so no turning of ends was needed. The new rods fit the bearings perfectly, unlike the old allthread, so no clicking.
Pics of the Y and Z stepper belt mounts, the new bearings in place, and other mods to come, as I get a chance to put them up.
If you want to see anything in particular, just let me know.
Don
Name:	new AB nut from dumpsterCNC installed on Y axis.jpg‎
ID:	44150   Click image for larger version
Name:	this is how AB nut mounts on new mount.jpg‎
ID:	44151   Click image for larger version
Name:	two X axis AB nut mounts with 5-8 inch hole another view.jpg‎
ID:	44152   Click image for larger version
Name:	z-axis lead nut mount-1.jpg‎
Name:	z-axis lead nut mount-2.jpg‎
Old 09-23-2007, 07:22 PM
CarveOne is on a distinguished road
Don,
Your upgrades are looking really good. Thanks for sharing the information and I'll follow your lead as cash is available.
CarveOne
"A $1,000 electronic device will almost always protect a ten cent fuse."
Old 09-23-2007, 11:06 PM
I think alot of people are following this lead. Alot of people are using .5" shafting & dumpsters nuts. The only thing yet to catch on is Ahren's bearing blocks.
Old 09-24-2007, 07:58 AM
justCNCit,
this is not intended to be a rant, but more of an explanation as to why I didn't buy them myself.
I looked at Ahren's site a while back and determined that the bearing blocks shown there are fine for the builders who don't have a mill or where a standardized block shape will work ok, as with the 8020 extrusion machines. The price is very reasonable for the amount of work involved in making them. I didn't see any note that Ahren will make custom shaped blocks for other machine designs.
Had there been a set available for the plans I'm building from then it would have added more than $100 plus shipping to my build cost. My bearing blocks need to be differently shaped, and I can mill them myself from the aluminum stock I already have on hand, so I didn't order them. I think that any low sales is not a quality or design issue as much as there will be a more limited market by not having available a small selection of kits for the more popular machine designs in addition to a standardardized bearing block for 8020 machines.
CarveOne
  #11   Ban this user!
Old 09-24-2007, 10:03 AM
ahren's Avatar
Hi guys,
I'd be interested to know if there are other "standard" designs for bearing blocks or motor mounts you all would be interested in. I made a run of the ones I have because they worked so well for my machine, but I realize they won't work for everyone. The setup time for custom blocks makes the pricing somewhat prohibitive, but I'm open to changing the design to make it more universally appealing.
I'm planning on releasing plans at some point for a complete 8020 machine, but I have a few details left to work out on the linear motion system (trying to keep costs down). Anyway, I don't want to hijack this thread, so feel free to PM me with ideas that you'd like to see become metal.
  #12   Ban this user!
Old 09-26-2007, 01:02 PM
more pictures.
Here are some more pictures of the upgrade. Instead of going into a long explaination of each picture, just ask for details on any pic.
Don
Name:	y bearing dual nut end.jpg‎
ID:	44314   Click image for larger version
Name:	y bearing dual nut end -2.jpg‎
ID:	44315   Click image for larger version
Name:	X  AB nut showing spacer for mount.jpg‎
ID:	44316   Click image for larger version
Name:	X  AB nut showing spacer for mount - 2.jpg‎
Name:	X  1-2 inch ID pulleys and nuts.jpg‎
ID:	44318   Click image for larger version
Name:	why its called a router bed.jpg‎
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 10:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
