| CNC Wood Router Project Log Post your CNC machine building log here only. |
#421
In my other build log, my larger 49x62 machine's gantry weighs about the same as yours and the NEMA23 Keling 495 oz-in motors KL23H2100-30-4BM (Dual Shaft) I'm using are more than adequate for the job. The NEMA23 Keling 382 oz-in KL23H2100-30-4B (Dual Shaft) motors will also handle it I'm sure and are $10 less expensive. You can find them here. For the 382 oz-in motors you should use Keling's 65 vdc power supply because the motors have a lower voltage specification than the 495 oz-in motors. Make sure the power supply voltage you use is within the input voltage range of the driver you use. I am using the Keling KL- 7220 72vdc power supply here. My drivers are the Gecko G203V and the breakout board is the CNC4PC C11G. Using two 495 oz-in drives on the X axis gives almost 1,000 oz-in torque at low speeds to move the gantry around, and it seems to have no problems doing it. I've had the accel rate up to 50 and all it does is shake the work table when it reverses direction. 20 to 25 is where I'm normally running it and there is no noticeable lag time on starts and stops. I have been really happy with this combination of parts and you'll find others here that have also used it with success. You will easily see jog speeds of over 1,000 ipm. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
#423
| My larger machine uses standard 1/4" x 72" CRS flat stock for the X axis rails and I have 62" travel once the extended carriages and router overhang is accounted for. The gantry allows a little over 49" travel so that I can cut MDF edge to edge. Future plans for it is to build a 10' long steel frame and transfer everything over to it and regain the use of the work table. I also have more upgrades planned for the 25x37 machine in this thread. CarveOne
#424
But rather buy right componets rather than wrong ones and then half spend more money! I was Self Employed cabinet maker for 30yrs mye wife wanted me to quit do to back injury! So went work as designer for store fixture company 4 yrs ago! My wife past away this last Nov. from cancer and youngest child graduates from high school here in week and is going into the airforce. So Iam wanting to go back to doing some form woodworking as bussiness! Have tablesaw,bandsaw,Bench 12" planer,combo edge spindle sander,mitersaw, sanders,drills,scrollsaw,9x32 2HP Benchmill Enco Brand and etc. So i figured needed to at least have some sort cnc router keep up with jones as they say! |
#425
I was in the USAF also. It was good duty and taught me enough electronics to make a decent enough living afterwards. You'll find a lot of ways to use your CNC machine. Some of it might even pay something for your efforts. Maybe you can find something that can become a paying service for the local cabinet shops, since you already know their business. CarveOne
#426
I will start build post as soon as find mye digital camera! Thanks for your reply and hope to get little help with wiring electronics from you since you have already done It will go after same componets you bought! Have fun in CNC world thier amazing machines to watch! R L Harris |
#427
Will help any way I can. There are many folks here with much better knowledge of the subject though. I don't get into the excruciating details so much as I just build it and see what happens. And I read a lot of the build logs and discussions. Some of it has even stuck in my head enough that I sometimes feel "dangerous". CarveOne
#428
Dam can,t find it only one other place to look dam crawl space storage have to move few shop tools to get in there and fend off few Spiders ![]() Also ordered Arhens Extended Linear Bearings Today! Signed up to Work Overtime next Sat and Sun that be extra $400 almost pay for those 203v |
#429
| Good to hear it. You won't be disappointed with the performance, and there is amperage to spare for larger motors later. CarveOne
| Pumelloman Solysylva 25x37 Router Build | pumelloman | CNC Wood Router Project Log | 280 | 03-14-2011 08:51 PM |
| Len's Solsylva CNC Router Build | bitbanger | DIY-CNC Router Table Machines | 7 | 06-05-2008 06:41 PM |
| My Solsylva router build... | cdsgraphic | CNC Wood Router Project Log | 27 | 06-11-2007 10:46 AM |
| solsylva router plans | Booge | CNCzone Club House | 1 | 01-23-2007 09:37 PM |
| Have you cancelled your Solsylva build? | Rance | DIY-CNC Router Table Machines | 1 | 01-20-2007 07:49 PM |
