Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 08-09-2007, 04:46 PM
Arcticfox46 is on a distinguished road
Convert to PC based
I have a router machine - not home built
I am thinking I "might" convert it to run directly from the PC.
The router has stepper motors for each of the three axis motions.
1) Do I need to purchase some "special" axis drive cards for the PC?
2) How would I power the axis drive stepper motors?
Old 08-09-2007, 04:56 PM
acondit's Avatar
acondit is on a distinguished road
It really depends on what kind of drivers it has now. If it has drivers that use step and direction signals, you may just need a breakout board and some software.
So the first question is what kind of drivers does it have now?
Alan
http://www.alansmachineworks.com
Old 08-09-2007, 05:06 PM
Not sure how to answer the question.
It is a Larken Router
It has a black box where the axis wiring plugs into.
It runs OK - but I was thinking that if the conversion was easy enough I would eliminate the black box and run from a PC.
I may not be knowledgable to do that. Also cost may hinder me.
So - I guess - the answer is assume that I was going from scratch and building a router.
Old 08-09-2007, 07:19 PM
acondit's Avatar
Well if you are serious, then I would open up the black box and see if I could identify the drivers. If they are Larken drivers, you might be able to identify the model and get some info that would be useful. If you just want to throw the black box away (why?), then you need to identify what kind of steppers to determine voltage and current required to drive them. That may dictate what some of your choices are.
By the way there is a Larken forum here where you might get more information. http://www.cnczone.com/forums/larken/
Alan
Old 08-10-2007, 08:05 AM
Al_The_Man's Avatar
AFAIK the Larken is already PC based, driven through the parallel port, the black box you are refering to is the drivers, which you will need in any event.
Is water based CNCadmin Safety Zone 44 10-15-2010 02:27 PM
Used CMM based DIY router? biomed_eng DIY-CNC Router Table Machines 1 10-16-2006 08:52 PM
PC Based Oscilloscopes Good or...? Smertrios General Electronics Discussion 11 09-22-2006 07:20 PM
dos based cnc software flyingmike Computers and Networking 14 11-25-2005 01:29 PM
Dsp Based mini cnc controller CNCadmin Product Announcements & Manufacturer News 0 01-05-2005 06:59 AM
