Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 07-31-2007, 06:39 PM
CheekieMonkies is on a distinguished road
Rockcliff Router Build, MFD
Hello,
I have started my very own build, thanks to everyone on these forums for such a lot of information and other things i'v found it very intresting reading / watching how everyone here is building there cnc tables.
I have included a link to my build log if your intrested in viewing so far, its very erly days yet and i'm still needing to buy other parts such as motors and so on. Small steps as they say.
My Build log can be forund on this link, its a new site for the uk: http://mycncuk.com/forums/viewtopic.php?f=46&t=8
Regards,
Old 08-01-2007, 07:53 AM
Kammo1 is on a distinguished road
Can't see no pics.
Old 08-01-2007, 08:47 AM
Hey Kammo1, you will need to register.
The settings are set so you cant download or view pics, like it is here unless you register, would be nice to haev some Uk company over there.
Have you done your own build ?
My build log: http://www.mycncuk.com/forums/showthread.php?t=7
Old 08-01-2007, 10:36 AM
Cutting bits
i'm going to be cutting 3mm hardbord, right now we cut 20mm X 20mm letters usign a fretsaw from this wood for making door plaqus.
What we would like to do is cut these on our new cnc router table, please can you advise me on the right cutting bits i should use on such small detail work for this kind of thing.
If you was to take the letter A, i will need to cut the inside of the A with a very small bit so as it get a close inside edge on the cut (i hope iv said that right), i'v been advised to use "Slot Bits" as they come in very small size's even half a mill, now i understand thats probably way to small for what i would be doing or is it ?
I'd really appreciate some help on this as its really quite an important issue for us right now.
Old 08-06-2007, 03:03 PM
Bump
Old 08-06-2007, 03:29 PM
gmfoster is on a distinguished road
Originally Posted by CheekieMonkies View Post
Bump
Most of us aren't going to register at another place just to look at pictures.
Sorry about that...
Garry
Old 08-06-2007, 03:37 PM
Understood, wasnt really hoping for that i'm just after some help mate.
Old 08-07-2007, 12:42 PM
Basically you can't easily do what you are asking...
The best vet would probably do this in two steps. Depending on the size of the letters pick a bit strong enough to hold up well and use it to cut all the letter except the really fine V's. Then do a tool change and cut out the inside corners. Of course this means you will have to hand massage almost all of you Gcode. The other option would be to cut out with a bit that will hold up then finis by hand via fret saw, file or a similar method.
A really tiny bit probably won't hold up to do very many whole letters. I would use an upcut spiral router bit for all the cuts..
Pretty much you just have to try things and see what works for you....
Garry
Old 08-07-2007, 02:08 PM
ok thanks for the heads up, i was looking at some 1mm bits today they are £15 well £10 to me as i get some discount. i think its gonna be trial and error like your saying. Maybe do that tho cut with bigger bit for the out sides then cange to smaller and new gcode with less feed rate so i can do the inside bits.
Old 08-10-2007, 08:54 PM
Hiya all, today i posted loads of new pics and posts about my build so far, i know some of you dont want to register at a new forum just to view the pics and so on, so i'v arranged for my pics to be viewable by guest's so please come and take a look as i would really like to share my log with members of these forums as well.
i know its abit out of your way to register but it dosnt take that long and i would apprecate your comments or advice you may give me.
My build log:
Click here
kind regards,
CheekieMonkies
  #11   Ban this user!
Old 08-10-2007, 09:13 PM
Hey thats looking real nice...
Garry
  #12   Ban this user!
Old 08-11-2007, 05:29 AM
yea i know i'm really pleased with it, just hope the sun stays out today for me to jump on it again. !
Regards,
Cheekie
Rockcliff Router Build lgroulx200 Rockcliff Machine 283 07-21-2009 07:34 PM
BobL's Rockcliff build boblon CNC Wood Router Project Log 21 03-27-2007 02:22 PM
My Rockcliff Build (not quite to plans) snoyce DIY-CNC Router Table Machines 24 03-23-2007 07:12 AM
