Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 07-04-2007, 11:16 PM
legomanww is on a distinguished road
Need some Advice
I'm working on building a moving gantry router. I am having problems mounting the motors and getting it so that the motors can actually move the gantry.
if I hold the motor on the coupling for the Z axis it works great, better than I expected it to at least. I attached the motor for the X axis roughly, but it can barely move the gantry. I'm not currently using a very high voltage supply on the motors, so that might be a problem for when I try and go faster, but it still has a hard time moving it at low speeds (3ipm).
The gantry moves relatively easy on the pipes.
It was quite a problem to get a nut mounted on the screw and attached to the gantry.
At this point I'm willing to scrap the bottom part of the gantry, and possibly even remake the panels for the X axis if that's recommended.
Does anyone have any suggestions about how to attach the motors?
Or about how to attach the nut for the leadscrew on the gantry?
How about an easy anti-backlash design? (my current one does not assemble very well)
Also, I'm really having a hard time figuring out how to mount the bearings for the leadscrew on all of the axis. Currently it is resting on some bolts that stick out for the Z axis and that seems to work ok, since it has weight holding it down.
But I can't figure out how to hold the bearings for the other two axis, at least not enough to actually hold weight. Should I just drill a hole exactly the size of the bearings and just shove it in there? or is there a better way?
Any preferred designs for any of these that can be made easily?
A big problem that I've had is my lack of construction ability. I have a hard time drilling a perpendicular hole through something, and I don't have access to a drill press or mill.
(Although I suppose now that the Z axis moves I could use it as a makeshift drill press once I get the motor mounted.)
I've kind of decided that once I finish this one, and get it working, that I will have it re-make most/all of the parts, to make it straighter and fit better.
Old 07-06-2007, 05:10 PM
acondit's Avatar
acondit is on a distinguished road
Legomanww,
Here is how I attached the motor on my router. The bearing block holds two bearings pulled into two pockets (one on each side of block) to act as thrust bearings. Then I bored a hole for the one bearing extension. I used aluminum standoffs to separate the motor from the router frame and used Lovejoy connectors to connect the motor to the leadscrew.
I think you are right about using the first one to rebuild a better second one.
Alan
ID:	40258   Click image for larger version
ID:	40261   Click image for larger version
http://www.alansmachineworks.com
Need some advice ceb5 General Metal Working Machines 8 07-02-2007 12:17 PM
looking for advice nelson j Employment Opportunity 15 06-26-2007 11:13 AM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
Need Advice Vern Smith Haas Mills 2 01-01-2007 02:54 PM
Looking for some advice DeusXmachinist Composites, Exotic Metals etc 5 04-07-2006 10:08 AM
