| CNC Wood Router Project Log Post your CNC machine building log here only. |
I have started to make a cnc mill I'm new to all this but I'm having a go. I made a wind turbine but could not make the blades all that well my hand . so I thou rt I would make a cnc mill to make the blades. I would like the working bed to be 1000MM by 500MM . one day i will make a web page for the cnc mill here some off the parts the bed is 30MM facing ply it is not supported in the middle i will have to see if it will bend (i think it will )
__________________ Warning. Fiddling with this equipment can kill you! Use this information at your own risk. |
![]() i have had to have some parts made i could not make them bye hand they cost £60 it-is a shame i could have made them with the mill when its finished umm
| hi the rails i got them from ebay i would like to change them for something big but thay will have to do for now i have got on with making my control box for the drivers and things
| I have got the z axis all done the plate witch holds the motor on is a bit thin I will change this for something stronger ![]()
| I have change the plate which holds the motor on the Z axis and also put a bearing to take out the play in the belt
#10
| here is the mill with some new rails which I got from ebay and the 5mm steel sheet for the bed of the mill
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
| Will I be able to buy food for my cats? | Faber.sum | CNCzone Club House | 10 | 10-10-2005 12:53 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 12:27 PM |
