Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 06-11-2007, 06:50 PM
ProDrawerCom
IQChallenged is on a distinguished road
My dust shoe
It's a plexi pan about 1" deep and bolted to the bottom of the router bracket. Then the vinyl flaps are attached. There's also a stationary secondary fence (because I could). The masking tape is temporary. I'll take it off after/if the concept proves itself. I'll also make it adjustable. Used another poster's idea of using a carpet runner for the flaps. Low dollar.
http://www.projectCNC.wordpress.com
Old 06-11-2007, 09:08 PM
Jason Marsha is on a distinguished road
Good work on the the dust shoe.
Did you polish that Bosch router, its damn shiny.
Jason
Old 06-12-2007, 07:24 PM
ProDrawerCom
Shiny Bosch
Jason
Actually there is a story behind that. Within a few months of buying the router it began to oxidize. It began to look more and more like cast iron. Not only was it ugly- it wouldn't slide up and down in the router frame. So Bosch rebuilt it. If I remember correctly they changed from aluminum to magnesium (or the other way around).
http://www.projectcnc.wordpress.com/
Old 06-12-2007, 09:12 PM
johnmac's Avatar
johnmac is on a distinguished road
Magnesium gets dark with age, then gets a white powder covering it when it oxidizes. Looks real ugly.
Old 06-14-2007, 06:12 PM
ProDrawerCom
Follow-up on dust shoes
After using it for a while the carpet runner, at least the one I bought, simply is not supple enough. It works okay most of the time but I like to lay a sheet of foam down and do test runs. That's a great test for the suitability of a dust flap material. The carpet runner flaps will drag the foam right out from under the clamps. I suppose that one of the commercially available see-throughs like ShopBot might be suitable. But it would cost me a half a yard or better to find out. I think I may just go straight to brushes. I found a hand brush in Home Depot the other day. It was genuine horse hair and I was amazed at how much softer it was than the synthetic ones. And I believe that's crucial given the pole-vaulting effect of brushes or flaps that get lined up just right and push up on the shoe rather than bend. McMasters stocks them. Stay tuned.
Old 03-02-2011, 10:13 PM
Peter Zicha is on a distinguished road
Your dust shoe is a cool idea , I am looking for some thing a little better than my vacuum pickup , actually something to aid the vacuum pickup
ID:	127953   Click image for larger version
Old 03-04-2011, 02:57 PM
tskguy is on a distinguished road
IQ, do you worry about the flaps getting drug under near the cutter??
Peter,
What motor is that on your machine????
Looks interesting.
Eric
Old 03-04-2011, 03:02 PM
Its a 2hp DC drive treadmill motor , I had the casing chromed
Old 03-04-2011, 03:24 PM
Very cool,
I actually thought about using one for my spindle. What did you use for a power supply and speed control? Im currently using a 1500watt RC brushless and powering it with HUGE 12v dc power supply. It works pretty well but Im looking at other options.
Eric
Old 03-04-2011, 05:29 PM
I use one of these to control the speed ( Link below ), cheep and it works on any router type motor , I have my DC treadmill motor going through a bridge rectifier so it converts AC to DC
AC or DC ELECTRICAL MOTOR VARIABLE SPEED CONTROL TOOL - eBay (item 400198317545 end time Mar-04-11 23:54:26 PST)
  #11   Ban this user!
Old 03-04-2011, 09:05 PM
Cool I have one of those!! Very smart. I think I may give it a try.
Ive seen those motors a bunch on ebay for real cheap.
Dust collector SPEEDRE DIY-CNC Router Table Machines 4 06-30-2007 08:45 AM
Dust Extraction sploo WoodWorking 12 04-06-2007 01:57 PM
Dust Mask or No Dust Mask Hogpaw CNC Plasma and Waterjet Machines 0 09-08-2006 05:57 AM
Dust/Chip Control...CNC Dust Enclosures Too_Many_Tools DIY-CNC Router Table Machines 17 07-29-2006 01:44 PM
Let’s see that’s dust collector automizer DIY-CNC Router Table Machines 5 03-15-2006 06:41 AM
