Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > CNC Wood Router Project Log
CNC Wood Router Project Log Post your CNC machine building log here only.
Old 05-30-2007, 02:38 PM
adamziegler is on a distinguished road
Ziegler's Machine Log
I have spent the past couple months working on my machine. I don't know if I could say its original or not, but it has been a learning experience. (I already have plenty of ideas and changes to make on the next build. )
Primary purpose will be to carve patterns and core boxes for metal casting. The primary machine will be 3 axis, but I have thoughts on adding a 4th (A axis rotating around X.)
I am using EMC2 for the software and HobbyCNC Pro 4 axis for the driver and steppers (200 oz-in). Drive screws are 18 TPI all-thread.
http://images.myonlinesite.com/cnc/index.php (Bottom of page has latest updates... links lead to directories with pictures and sometimes flash videos.)
I am running into a bit of mental block coming up with motor mounts and drive nut (threaded rod coupler) attachment. Any thoughts would be welcomed. I have toyed with a few different ideas, and just haven't settled on anything definite yet.
I still have yet to pick out a router for the machine, but have my eye on a couple trim routers.
ID:	38221   Click image for larger version
Old 06-01-2007, 10:47 AM
Here is my updated log also found at: http://images.myonlinesite.com/cnc/index.php (you can use backspace on most browsers to return to the previous page in the frame below.)
Old 06-04-2007, 02:29 PM
As you can see from my log above, over the weekend I managed to come up with a solution for the stepper mount and drive nut mount. I also jerry rigged up a pen and was able to "plot" some code out on a piece of paper.
Lots of tweaking to do... especially with the alignment of the Y nut.
Now to finish the Z carriage!
Old 06-05-2007, 05:24 PM
aerojc is on a distinguished road
nice looks
you opted for larger rails.
are those skate bearings?
Old 06-06-2007, 08:23 AM
Yes... 1.5" conduit (actually about 1.74") and they are skate bearings.
If I did it again, I might go with smaller rails and a different support system for the rails... similar to the way http://www.solsylva.com/ does it. However, the cove cut rail supports seems to work well so far.
Old 06-06-2007, 10:31 PM
I added June 5th and June 6th to my cnc log. Last night I spent most of my time tweaking the machine, and computer settings.
Tonight I finished up the Z box.. I hope to add the screw tomorrow.
I dont really have a clear idea on how I will attach the tool. I want to be able to add and remove different tool mounts as I hope to experiment a bit.
Maybe I can drill a grid of holes in the front of the z box.
Old 06-12-2007, 10:15 PM
Added the screw and drive nut to the z box tonight. Still no clear decision on the tool holder.
Old 06-14-2007, 11:54 PM
It's Alive!!!!
Made the tool mount tonight, and wired up the cables to all 3 axis. The machine is alive!! Its great joy to see the thing run! Too bad I didn't have a single proper bit to use... well I did, but then I didnt have the right sized collet for the bit :-/
Old 06-15-2007, 09:00 AM
picbits is on a distinguished road
Looking good
I'm just working on the electronics for mine at the moment but it moved under its own steam for the first time today
Old 06-15-2007, 09:25 AM
Right now I am using a wimpy little 12v computer power supply for testing purposes, but I have the parts to build a larger power supply at higher voltage. I also need to add some limit / home switches.
There was a cross support "plate" for the back of the y gantry that added a significant amount of stability to the machine... but I wasn't paying attention last week and I cut it up to make something else. Anyway... that too needs to be added to the machine.
Sealing the machine is also on the list of things to do. I would hate to have moisture ruin it. Maybe I should leave it alone... so that I can have an excuse to make another one!
  #11   Ban this user!
Old 06-15-2007, 10:11 AM
I know what you mean about making mistakes.
I mounted the stepper for the Y Axis on the wrong side of the machine so it will now have to sit on the opposite workbench it was intended to sit on.
I've got a load of 18V 400VA toroidal transformers earmarked for the motor drive on mine but even running my steppers at an average of 2 amps (I can go up to 2.4 amps per phase on two phases so 4.8A) its running rather well.
I will have to play with it when I get my own drives sorted out
  #12   Ban this user!
Old 06-28-2007, 07:47 PM
Side note... Those of you using plain-ol all-thread/threaded rod and threaded rod couplers for your drive screws and nut..... rub the screw down with bees wax. It makes a world of difference for how smooth it runs, and it doesn't attract debris like oil and other lubes do! I am also able to run my machine about 5 IPM faster without it stalling too.
Use Machine Shop vs. Buying Machine imp22b General Metalwork Discussion 15 06-06-2007 06:33 AM
G Code Variances from machine to machine? Miguel Gonzalez G-Code Programing 16 03-28-2007 03:31 AM
Mach 2 on old machine = great machine foamcutter Machines running Mach Software 6 12-16-2005 12:11 PM
Getting work(gcode) from machine a to machine b strat DIY-CNC Router Table Machines 9 07-07-2005 02:13 PM
